03-30-2020, 03:37 PM | #1 |
Rep 18
G20 Seat Heating Distribution?
Does any one know if you code the front drivers seat heat distribution with eSys that it actually does anything and works as it should? Ie does the G20 have separate seat heat pads?
I know you can code it and get the settings up in the AC/Idrive menu, but do they actually do anything? I.e can you have just the seat back hot without the bottom? Thanks |
03-30-2020, 03:43 PM | #4 |
Rep 299
03-30-2020, 03:47 PM | #5 |
Rep 18
04-19-2020, 09:39 AM | #8 |
Rep 56
There is only one SM module in G20, so You can enable it on driver's seat only.
also Driver seat heating pad is at bottom and back(2 pads)... but... only one thermometer. It should works only on bottom heating pad. One more information, you will get an error if you check status with ISTA. |
siegester344.50 |
04-21-2020, 06:23 PM | #9 |
Rep 1,479
Drives: 2020 M340Xi (G20)
Hi,
I have the heat distribution coded in my car. While it won't hold a setting for front passenger, it seems to be working on driver's seat. While I haven't used ISTA on my car, I ran diagnostics from my MX+ OBDII and it can back error free -- and I know it works as I used on my son's Mini
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
04-21-2020, 06:55 PM | #10 | |
Rep 56
I guess, it pops up some condition. |
02-07-2023, 03:47 PM | #11 | |
Rep 4,132
i gather in 2020 it works only for driver seat - any advance on passenger seat? |
