      03-30-2020, 11:42 PM   #1
GSH527
Drives: 2019 BMW X5
Alignment after changing tires
Have you guys had alignments after changing tire sizes?
I'm going from a 19" winter set up to a 21" summer, wondering how it effects speed indication, lane departure, and wear on tires adversely.
      03-31-2020, 08:11 AM   #2
VTENGR
1053
Drives: 2020 X5 M50i
Check and see if the outside diameter of the tire is the same. It seems that as the rim gets larger, the profile of the tire gets smaller, so the O.D. of the wheel stays approximately the same.
GSH5271.50
      04-04-2020, 01:06 PM   #3
Pro55
Drives: BMW X5 G05 30d
Just select the new tyre size that is on the rear axle in the I drive and you are good to go. The system automatically updates the speedometer accordingly.
PS. As long as its the sizes approved by bmw. look in the I drive to confirm.
GSH5271.50
      04-04-2020, 01:55 PM   #4
eagle_bmw
Drives: 2019 BMW X5 40i
In addition to previous post, entering the correct tire size in iDrive enables the system to correctly flag loss of tire pressure, per manual (see TPM section).
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs]
GSH5271.50
      04-04-2020, 01:56 PM   #5
GSH527
Drives: 2019 BMW X5
Thank you for these two posts.
Where in the I drive system can you find the tire size options?
      04-04-2020, 01:58 PM   #6
eagle_bmw
Here you go.
2019 X5 40i M-Sport
      04-04-2020, 01:59 PM   #7
GSH527
Drives: 2019 BMW X5
Here you go.
Awesome! Thanks again
