BMW 5-Series (G30) Forum Mechanical Maintenance - Break-in, Oil, Fluids, Servicing Gas tank won't fill up
      04-05-2020, 11:44 PM   #1
YoungOG08
YoungOG08's Avatar
Drives: 2018 540XI
Hey guys I'm having problems when fueling my car I have 2018 540 with 21k miles on it and everytime I try to fill up my tank the car won't take more than half a tank when the tank is halfway of gas and I try to fill it up it'll just start spilling and won't take more gas
Have you guys encounter this problem lmk please any advise since all the dealers are closed
      04-06-2020, 06:11 AM   #2
AP
AP's Avatar
2777
Drives: G30 M550
I will state what is probably the obvious but you are inserting the pump nozzle correctly? Not too far out or at an angle that might be causing the pump to stop!
Is this the same gas station and Sam pumps, not changed for any reason?
      04-11-2020, 06:22 PM   #3
YoungOG08
YoungOG08's Avatar
Drives: 2018 540XI
I'm doing everything correctly the pump just stops when the tank is halfway whether it's automatically or I'm pump it myself
      04-12-2020, 03:06 AM   #4
AP
AP's Avatar
2777
Drives: G30 M550
very odd then. I'm out of ideas then.not sure wher eyou are but with the corona issue, your dealership may well be closed but they may be open to call so worth giving them a ring to see if anyone has any ideas.
      04-21-2020, 10:54 PM   #5
YoungOG08
YoungOG08's Avatar
Drives: 2018 540XI
It's the gas tank gauge
      04-25-2020, 08:40 PM   #6
BlueSander
59
Drives: M550i
have you try running it till almost empty and refill again?
      10-01-2020, 03:09 PM   #7
GeorgeI
Drives: 540i MSport
G30 540i MSport  [0.00]
Yup. When the tank is half empty, you can only put in half a tank.
Appreciate 3
      10-02-2020, 07:23 PM   #8
johnnyp420
johnnyp420's Avatar
Drives: 2018 BMW 530e M sport
2018 BMW 530e  [0.00]
I've had this problem in my E39 M5. It ultimately led to needing the entire gas tank and fuel filler assembly replaced. The sensor in the gas tank was bad. Could also be vapor lock in the fuel lines.
      04-03-2024, 09:00 AM   #9
m550ilover
Drives: m550i
Did you ever figure this out I seem to be having the same problem
5post
