Experience with OEM N55 spark plugs in the N54 engine?
04-16-2020, 08:34 AM | #1 |
Rep 4
Hi.
I have been searching posts like crazy since I ordered Bosch ZR5TPP33 spark plugs for my 335i. I have just done the DCI and I plan to MHD Flash (stage1) next week. So my question is that on the site bmwsparkplugs . com they state that: "Note that the Bosch plug is actually the N55 OEM plug, which was made one-step colder by BMW after they realized the N54 OEM plugs were a little too hot. These plugs run great on the N54." I am thinking this is all very good however on the whole internet I cannot find anybody that writes that the Bosch ZR5TPP33 or the ZR5TPP33-S for that matter is a spark plug which indeed is usable with the N54 engine. Have anybody here used/tried the Bosch ZR5TPP33 / ZR5TPP33-S spark plug with the N54 engine? and if you did please tell if they are working as they should with the N54 engine. Kind regards Thomas |
04-16-2020, 09:35 AM | #2 | |
Rep 16
04-16-2020, 10:45 AM | #3 |
Rep 3,727
Most people either run 1 step or 2 step colder NGK plugs. I would do 2 step colder if you plan on going FBO + E85. Otherwise 1 step is fine.
1 step - NGK 97550 2 step - NGK 97506 See here: https://twistedtuning.com/products/n...um-spark-plugs
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
04-16-2020, 12:36 PM | #4 |
Rep 1,245
I run N55 plugs and they work fine, I tried them at stock gap and didnt have issues for a little while but ended up getting some spark blowout on a custom map, so I gapped them to .020.
If I were doing it again id just put n54 stock plugs back in it, those never gave me issue, custom file or not and no gapping needed for 25k miles.
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50 11.61 @ 117.5 New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets |
04-16-2020, 01:33 PM | #5 | |
Rep 2,013
So they realized it was a little too hot but continued using it on the N54 Engines all the way to 2016 on the Z4 35is? Mind you they stopped making n55 before 2016 . The B58s were in.
335i e92 TPC 19Ts
04-16-2020, 02:35 PM | #6 | |
Rep 1,245
i have spotless logs on a hot 93 and e50 tune with stock plugs that have 25k miles on them
04-17-2020, 12:51 AM | #8 |
Rep 4
thanks for your comments
Since I have already ordered the N55 spark plugs, I will gap them to 0,022" and install them in my car when I get them. I will let you all know if I feel any differences or if it misfires etc. Kind regards Thomas |
