F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > 3 and 4 Series Ordering / Pricing / Order Tracking Forum (and European Delivery) > Bmw f30 335i misfire but no code!!
ARMA SPEED
      04-19-2020, 07:53 PM   #1
Marcoadj
Marcoadj's Avatar
Drives: Bmw f30 335i
Hello i have a 2014 335i fbo on mhd. I experienced very choppy driving under light throttle but in wot it pulled hard. Later when i did a pull and 2nd gear thru 4th was fine but when i shifted into 5th my car misfired bit i dont get a code. So i changed spark plugs to ngk 97506 gapped at 0.022 and now it waymore choppy in light throttle.
Marco
      04-19-2020, 07:57 PM   #2
pongkin
Drives: f30
igintion coils
      04-20-2020, 04:07 PM   #3
Marcoadj
Marcoadj's Avatar
Are you sure? My car only has 49k miles on it
Marco
      04-21-2020, 11:00 AM   #4
pongkin
Drives: f30
read the codes see what it pulls up
      04-21-2020, 11:30 PM   #5
Marcoadj
Marcoadj's Avatar
I dont get any codes
Marco
      04-22-2020, 11:13 AM   #6
pongkin
Drives: f30
does it always misfire when u go 5th?
im leaning towards coils or tune
      04-22-2020, 01:22 PM   #7
Marcoadj
Marcoadj's Avatar
Only misfired when i shift to 5th in wot. Since changing sparks the car now is more choppy.
I only did a few pulls and everytime it did it
Marco
      04-22-2020, 01:24 PM   #8
pongkin
Drives: f30
at idle it chops?
      04-22-2020, 01:28 PM   #9
Marcoadj
Marcoadj's Avatar
It starts good but then idle gets choppy
Marco
      04-22-2020, 01:29 PM   #10
Marcoadj
Marcoadj's Avatar
Do u think it could be due to having e30 mix in the tank for too long without being started
Marco
      04-24-2020, 01:27 PM   #11
pongkin
Drives: f30
idle is choppy?
unplug each ignition coil the engine should sound react when unplugged, if it has no effect that coil is bad
      04-24-2020, 02:53 PM   #12
Marcoadj
Marcoadj's Avatar
Very lightly choppy. Every 10 -20 seconds it stutters when i drive and hit 60 mph my car starts shaking. Im curious why my cars misfires got worst after i changed plugs?
Marco
      04-24-2020, 08:54 PM   #13
pongkin
Drives: f30
well like i said do the ignition drop test at idle as you say it chops at idle.
      04-24-2020, 09:30 PM   #14
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
What code reader are you using?
      04-24-2020, 11:30 PM   #15
Marcoadj
Marcoadj's Avatar
I dont get any codes as in i dont get any codes that popup in my dash or idrive.
Marco
      04-25-2020, 12:18 AM   #16
cfm56d7b
You need a device called code reader which connects to OBD port and reads stored fault codes. There is undoubtedly one stored reflecting symptoms you reported.
Foxwell / Schwaben NT510 is a reasonably priced code reader.
      04-25-2020, 12:55 AM   #17
Marcoadj
Marcoadj's Avatar
I have one and on mhd when i read the codes i have none.
Marco
      05-01-2020, 09:01 AM   #18
pongkin
Drives: f30
so whats the outcome?
      05-18-2020, 02:25 PM   #19
Marcoadj
Marcoadj's Avatar
Im now getting these codes
Marco
      10-16-2022, 04:29 AM   #20
jturner
Drives: BMW 335i
Hey did you ever fix the issue
Jack Turner
f30post
