have wastegate rattle again, is it bad for engine? or can i wait?
09-15-2008, 10:32 PM | #1 |
17
Rep 305
Hello everyone,
Just bought an 07 335i with 25k miles on it, previous owner said he just had a wastegate actuator replaced recently and said he thinks it was only one of them. Two days later after having the car now I have the infamous rattle on decel from 2000rpm to 1500rpm. Does this issue negatively affect the engine in any way? I'm moving within a week and don't want to have the car in the shop for up to two weeks until i'm settled in a couple weeks. Is it ok to hold off on taking it in? or is it bad for the engine, etc? Also could it be something else? Very slight metallic rattling/ticking between 2000 and 1500 rpm. |
09-15-2008, 10:38 PM | #2 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
No harm at all. Just annoying. I'd wait for another couple of months until BMW has an fix/update that doesn't result in decreased boost response.
Shiv |
09-15-2008, 11:59 PM | #3 |
Rep 2,558
http://www.bmwtis.com/tsb/bulletins/...p/B111307g.htm
The important excerpts from the bullitin, for those interested: 1) Run test plan. 2) The test plan will conclude with an instruction to replace the wastegate actuators; ignore this instruction. Reprogram the DME; improvements are included with the following I-Levels: E90, E92, and E93 (335i and 335xi), E89x-08-03-530 or higher 3) After programming is completed, if the noise is no longer present, take no further action. If the noise is still present, replace both of the turbocharger wastegate actuators in accordance with Repair Instruction RA 11 65 580, Replacing vacuum unit (wastegate) (N54).
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
09-16-2008, 12:08 AM | #4 |
17
Rep 305
alrighty, thanks for the insight shiv. I do have the Dinan stage 2 flash if that makes a difference. Its barely noticeable unlike the couple videos on youtube where its INSANE and flapping all the time haha.
09-16-2008, 08:52 AM | #5 |
Modder Raider
755
Rep 8,633
Drives: M3
I wonder who's videos those are. hmmm.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
09-16-2008, 08:53 AM | #6 |
Rep 2,558
probably someone who REALLY f'ed up their car
09-16-2008, 09:01 AM | #7 |
Modder Raider
755
Rep 8,633
Drives: M3
I don't think you got it.
I made those videos before I got it fixed by the dealer. I came up with a temporary fix for the wastegate rattle, but this fix popped out after spirited driving.
09-16-2008, 09:30 AM | #8 |
Rep 2,558
haha i know, man... i was just playin'
09-16-2008, 08:07 PM | #9 |
17
Rep 305
ok, I just got a look at the work order for when the actuator was replaced, turns out BOTH actuators were replaced!!!??? How the hell is this happening again I thought they improved the part? It seems worse on cold start as well. what the hell could it be?
09-17-2008, 10:41 PM | #11 |
Rep 2,558
y don't u just take it back in and ask them (BMW)?
09-17-2008, 10:45 PM | #12 |
17
Rep 305
i will in a week or so because im moving this saturday and can't have the car in the shop here! I just want to know if its happened more than once to anyone since i thought they replaced the actuators with an improved part? or if it could possibly be the butterfly exhaust valve rattle that i just read about
10-16-2008, 12:35 PM | #13 |
Rep 2,558
getting actuators replaced
So I brought my car into the BMW dealership to get the wastegates replaced... I came to pick up my car this morning and even after both wastegates were successfully replaced, the noise is STILL THERE. Actually, the rattling is WORSE than when I first brought the car in... I told the SA to take it back and fix the problem, and they are taking a look right now (I'm at the BMW dealership as I type haha).
I had to argue with the tech a little because he was saying that the noise, to a certain extent, is normal... but obviously not as badly as mine is doing right now... Here's a video of the noise BEFORE... and it's WORSE now... [u2b]ViuBG9s3a6w&fmt=18[/u2b] Anyways... good to know that failed wastegates are not harmful for the engine/turbos... but it his hella annoying... hope they fix it soon...
10-16-2008, 01:00 PM | #14 | |
Rep 3,161
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/ SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/ SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/ |
10-16-2008, 08:11 PM | #15 |
ASR Turbos+LSD+Meth= :D
73
Rep 1,517
Drives: E92 335i
you didnt try Mr.5's fix? the turn or two on the rear wastegate actuator arm?
2007 335i Coupe Mods: Check the Garage |
10-16-2008, 09:27 PM | #16 | |
Modder Raider
755
Rep 8,633
Drives: M3
Seriously, if people don't know what they are doing then they shouldn't do what i suggested.
10-16-2008, 11:01 PM | #17 | |
Rep 2,558
Plus, BMW says the problem with my wastegates is actually a leak from one of the tubes going to the solenoid... so Mr. 5's fix probably wouldn't be applicable in this case anyways...
10-16-2008, 11:29 PM | #18 | |
Modder Raider
755
Rep 8,633
Drives: M3
If you don't feel comfortable with it then that's perfectly fine. Just let the dealer do their job.
10-17-2008, 05:42 PM | #19 | |
73
Rep 1,517
Drives: E92 335i
If your wastegate truely is leaking? you should hear a hissing i would think... i know for my friends scion tC turbo we put positive pressure on the system to check for boost leaks, which there were some and we hear a "ppssssss" sound. this however is not something as easy as using two wrenches. if you have any specific details reguarding the Mr. 5 fix, please do not feel strange to PM me, Tommorow, i will be at fixxfest but sunday i will be home and ready to answer if need be. Also i doubt Mr. 5 would mind to answer a few specific questions on the fix, but i dont like speaking for others. So yeah, please try the fix before you let BMW update or put new stuff on :P
2007 335i Coupe Mods: Check the Garage Last edited by oddjob2021; 10-17-2008 at 09:56 PM.. |
10-17-2008, 05:48 PM | #20 | |
Rep 2,558
10-17-2008, 05:52 PM | #21 | |
73
Rep 1,517
Drives: E92 335i
10-17-2008, 06:06 PM | #22 |
Rep 4,632
in your case, i would bring it back to the dealer since they already did the software update and new wastegates and such.
the problem is pretty simple, there either not adjusting to spec accordingly or something else. bring it back until they fix and replace with new parts, with what is needed. your knee deep thus far. GL man. |
