04-29-2020, 09:37 AM | #1 |
Rep 16
How many concrete flags in the boot?
As the title says really. How many 40kg concrete slabs do you reckon I can carry in a G20 at one time without bottoming out the suspension?
04-29-2020, 11:34 AM | #2 |
Rep 466
Drives: BMW G42 M240i XDrive
At a guess 6 - 7, that would be about the same weight as three passengers
Dan
G42 /// M240i Thundernight |
04-29-2020, 01:58 PM | #3 |
Rep 3,216
Bottoming out the suspension is only one of your concerns.
Lots of weight at the back = front being high up = far less effective steering. Having done the same with 200kg or so (in the F31, which is a bit more 'designed' to carry stuff in the boot), I can confirm it's not the most wonderful experience. Might only weigh the same as 3 rear seat passengers, but the weight is now slung out behind the rear axle, instead of directly above it |
Alanli72253.00 |
04-29-2020, 04:03 PM | #4 |
Rep 343
Found this in the specs for my M340i Touring....
Weight, unladen, to DIN/EU kg 1770 / 1845 Max load to DIN kg 595 Max permissible weight kg 2365 Max axle load, front/rear kg 1095 / 1345 Max trailer load, braked (12%)/unbraked kg 1800 / 750 Max roofload/max towbar download kg 75 / 75 |
04-30-2020, 06:01 AM | #5 | |
Rep 114
Digital drive: F90 M5
Analogue drive: Ariel Nomad |
04-30-2020, 06:55 AM | #6 |
Grumpy Old Git
443
Rep 923
Drives: BMW G20 330i RWD M Sport
Agree ... that makes sense....
Retired:
F10 520D M Sport E60 520D SE Volvo S60 type R |
06-02-2020, 09:48 AM | #8 |
Rep 3,216
06-03-2020, 01:06 PM | #9 |
Permanently confused
1160
Rep 1,701
If anyone is interested I had five bags of builders sand in the boot of my G20 yesterday.
Only wanted two but five minimum order. You're welcome.... |
06-03-2020, 01:54 PM | #10 |
Rep 114
You'll probably find there's 3 bags worth of loose sand still in there. Gets everywhere doesn't it...
