05-22-2020, 12:12 PM | #1 |
Rep 4,653
Dashcams
Hi,
I thinking of getting one fitted ( one of the smaller ones ) do most people just wire it into the socket under the glovebox - what other options are available if you want something a bit more permanent?
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
05-22-2020, 12:49 PM | #2 |
Rep 197
I've been thinking of getting one for a while and keep putting it off.
I like the look of the Blackvue front/rear cameras - not a fan of the cameras with screens - would rather have something discreet. Parking mode is something I'd like for those bumps and scrapes that happen in car parks etc. so need to look into that. Would also be interested what other folk have and how they're setup.
BMW 330e M Sport plus lots of toys
05-22-2020, 01:49 PM | #3 |
181
Rep 379
I power mine through the OBD port with an adapter, works for my needs where it's switched off from parking mode at home when my CCTV is monitoring the car then flick the switch on when in a supermarket car park for example to monitor using parking mode.
I'm using BlackVue front & rear cameras. https://www.halfords.com/technology/...le-619198.html |
05-22-2020, 02:00 PM | #4 |
Rep 8,516
I went the whole hog with my Thinkware F750 dual camera and wired it to a switched live and perm live.
Works very well.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
Soul_Glo13388.00 |
05-22-2020, 02:06 PM | #5 |
Rep 197
If you fail to power the OBD off, does it continue to drain the battery, or will it switch itself off after a set amount of time?
05-22-2020, 02:15 PM | #6 |
Rep 213
Went for the VIOFO A129 front only as I'm in a f33. Wired to the 12v socket under the glove box. Works well as I don't use the socket as installed a wireless charging tray too. I went for the Viofo as it's small and discreet. Also slides off the gps mount when leaving the vehicle. Recommended
05-22-2020, 04:15 PM | #7 |
5935
Rep 10,312
05-22-2020, 04:25 PM | #8 | |
Rep 4,653
Cost not the issue I'll pay what I need to.
Steve Roberts UK
05-22-2020, 05:06 PM | #9 | |
5935
Rep 10,312
Cellink NEO battery is about $300 but more than worth it as the main battery is not used to support parking mode recording. Two resources to start the research: - www.dashcamtalk.com - www.blackboxmycar.com; where I purchased Cellink NEO battery |
05-22-2020, 08:14 PM | #10 | |
Rep 525
Viofo a129 front and rear cam, so I have parking mode. Very easy to do and the camera wires all tuck easily behind the linings. No need to pull out any trim. |
05-23-2020, 01:42 AM | #11 | |
143
Rep 347
Also what route did you run your wires back to front of the car? |
05-23-2020, 02:09 AM | #12 |
181
Rep 379
It has battery discharge protection. Guessing my option wouldn’t be any use if wanting to leave parking mode on for long periods of time, I did look at the Cellink battery pack option but it was more expensive than the cameras so I didn’t bother.
05-23-2020, 02:29 AM | #13 |
Regular user
225
Rep 965
Drives: F30 330D M-Sport Auto
Another one for the VIOFO.
Mine's wires to the perm supply for the overhead lights.
05-23-2020, 02:54 AM | #14 | |
Rep 11
The PSU to step down for 12v-5v always concerns me since I had one once that interfered with the DAB reception. |
05-23-2020, 02:58 AM | #15 | |
Regular user
225
Rep 965
https://www.ebay.co.uk/itm/Nextbase-...EAAOSwIqxcSlvh
05-23-2020, 03:29 AM | #16 |
Rep 22
I have a Thinkware F800 Pro (Front & Rear), bought it when Amazon had it on offer for £259. It's hardwired to the fusebox in the boot (I had it installed by a mobile auto electrician). Smaller than it looks, about the size of a cig packet and easily slides off its mount if you want to remove it.
05-23-2020, 04:04 AM | #17 | |
Rep 525
the 3 links below are what i used to fit mine. + i had to youtube how to use a multimeter. like the bloke in the other forum thread- i also had to extend my hardwire kit by about 30cm - again very easy to do, some wire, some solder, and electrical tape. as for wire placement i followed the youtube link below. i'm pretty sure that by now, every single possible question about dashcams have already been answered in this forum. https://www.blackboxmycar.com/pages/...e-hardwire-kit https://f30.bimmerpost.com/forums/sh...4&postcount=17 https://f30.bimmerpost.com/forums/sh...80&postcount=7 (i used the same fuses as this guy) Last edited by gippy; 05-23-2020 at 04:19 AM.. |
05-23-2020, 04:06 AM | #18 |
Rep 11
05-23-2020, 02:30 PM | #19 |
Regular user
225
Rep 965
No, it's always been crap
05-25-2020, 08:33 AM | #20 |
Rep 512
Drives: 320i M Sport Shadow Edition
I like the Blackvue Dashcams, currently on my 2nd one as the first one has now gone in my sons car.
I currently have the 2ch 590W which is really good and discreet, managed to tuck the rear camera right up against the headliner so it I out of the way and cannot be seen in the rear view mirror.... then it’s hardwired into the fuse box in the boot. |
05-25-2020, 09:42 AM | #21 | ||||||
11001
Rep 32,881
It did make my DAB reception worse, but it wasn't great before. Using internet radio on carplay with my EE 4G is far more reliable either way. |
