06-11-2020, 08:54 AM | #1 |
Administrator
40322
Rep 21,232
2021 BMW X5 xDrive45e PHEV Arrives With Updates
BIMMERPOST NEWS The 2021 BMW X5 xDrive45e PHEV Sports Activity Vehicle. June 10, 2020 New 3.0 liter inline 6-cylinder turbocharged plug-in hybrid drivetrain. Larger 24 kWh battery for estimated 30-mile electric only range. MSRP of $65,400 plus $995 Destination. U.S. market launch July 2020. For 2021 X5 xDrive45e Ordering and Pricing Guides see: https://g05.bimmerpost.com/forums/sh....php?t=1727830 Woodcliff Lake, NJ – June 10, 2020…Today, BMW proudly launches the 2nd generation plug-in hybrid X5 Sports Activity Vehicle, the newest addition to the U.S. X5 lineup. The U.S. X5 xDrive45e arrives with a SULEV Super ultra-low emissions vehicle rating which can bring additional benefits in states which offer special consideration to drivers of electrified vehicles, such as high occupancy lane access stickers. The X5 xDrive45e is built at Plant Spartanburg, South Carolina, BMW Group’s largest global production plant. In 2019, the high-voltage battery assembly area at Plant Spartanburg doubled in size in preparation for the new X3 xDrive30e and X5 xDrive45e. 120 people currently work on the battery assembly line. New 6-cylinder BMW Twin Power Turbo PHEV Drivetrain The new x5 xDrive45e greatly enhances performance over the previous X5 xDrive40e with a 3.0 liter 6-cylinder TwinPower turbocharged internal combustion engine (replacing the previous generation’s 2.0 liter 4-cylinder TwinPower turbocharged motor) BMW’s latest eDrive technology and a larger, more advanced high-voltage electric battery. The combined power of the new PHEV drivetrain is 389 hp, a bump of 81 hp over the previous generation. Torque is now 443 ft-lb, an increase of 111 ft-lbs. 0 to 60 mph acceleration time is 5.3 seconds, 1.2 seconds faster than before. The prodigious amount of torque also allows for a factory-installed optional trailer hitch (rated for 7,200 lbs. of towing). The high-voltage battery grows in size to 24 kWh, up from the previous X5 xDrive40e’s 12 kWh capacity. As a result, electric-only range doubles from a previous EPA rating of 14 miles to a new EPA estimated 30-mile range. Electric-only top speed increases from 75 mph to 84 mph. The high-voltage battery is positioned in the underbody of the X5, minimizing impact on cargo space. With the rear seats up, cargo space is only 0.8 cubic feet less than the standard X5. With the rear seats folded, cargo space is 1.1 cubic feet less. Drive Modes The X5 xDrive45e features three drive modes: Hybrid – the default mode upon start up. This fully automatic setting allows the advanced electronics to determine the most efficient or performance-oriented combined use of gasoline and electric power based on driver input. Electric-only driving may be experienced at speeds up to 68 mph in this mode. Electric – This electric only mode can be used at speeds up to 84 mph. The driver can change back to hybrid mode by either pushing the throttle pedal through the kick-down position or via the eDrive button on the center console. Sport – This keeps the combustion engine engaged for particularly sporty driving and allows for more aggressive energy regeneration from engine and mechanical braking. Intelligent xDrive all-wheel drive and Sport Steptronic transmission The BMW intelligent xDrive system offers a rear-biased setup to enhance both spirited performance driving and all-season traction on differing road surfaces, from dry to slippery. The standard eight-speed Sport Steptronic transmission’s intelligent connectivity enables it to adapt its shift strategy according to the route and driving situation by working with the navigation system and if equipped, combining this data with information from the Active Cruise Control system’s radar sensor. This makes it possible for the transmission to shift proactively instead of reactively insuring that the vehicle is always in the correct gear for the upcoming road conditions. Suspension A double-wishbone front and five-link rear suspension give the new BMW X5 xDrive45e agile yet comfortable road handling plus enhanced traction off the beaten track. The standard Dynamic Damper Control system uses electronically controlled shock absorbers to sharpen the X5’s handling dynamics at the same time as increasing ride and suspension comfort. The driver can select from the two performance settings – Hybrid or Sport – using the Driving Experience Control switch. The standard two-axle air suspension offers individual control for each corner using an electrically driven compressor with pressure reservoir, making it possible to balance out an unevenly loaded car. Thanks to the linkup with the Dynamic Stability Control (DSC) system, the vehicle load registered by the air suspension’s sensors can also be factored into braking modulation. The X5’s ride height can be changed among five selectable levels at the touch of a button. The driver is also able to adjust the body’s ground clearance for off-road driving to a maximum of 1.6 inches above the standard setting. Another button lowers the car’s height by 1.6 inches to make loading and unloading of the vehicle easier. Wheels and Tires Standard equipment on the 2021 X5 xDrive45e are: 19 x 9.0 inch V-spoke Style 734 wheels with 265/50R19 all-season run-flat tires. Optional wheel and tire packages include: 20 x 9.0 inch V-Spoke Style 738 wheels with 275/45R20 all-season run-flat tires. 20 x 9.0 inch M Star-spoke Style 740M wheels with 275/45R20 all-season run-flat tires 21 x 9.5 inch front and 21 x 10.5 inch rear Style 744 wheels with 275/40R21 front and 315/35R21 rear performance run-flat tires. 21 x 9.5 inch front and 21 x 10.5 inch rear Style 741M wheels with 275/40R21 front and 315/35R21 rear performance run-flat tires. Exterior Paint Finishes The X5 xDrive45e is available in a choice of 9 non-metallic and metallic paint finishes. Alpine White (standard) Jet Black (standard) Carbon Black Metallic Black Sapphire Metallic Dark Graphite Metallic Mineral White Metallic Phytonic Blue Metallic Arctic Grey Metallic Manhattan Green Metallic Interior Upholstery and Trim Standard Sensatec upholstery in either Canberra Beige/Black or in Black offers leather-like surfaces while providing additional wear resistance for active owners. Optional Vernasca Leather in: Ivory White Canberra Beige Coffee Cognac Black BMW Individual Extended Merino Leather is available as an option in: Ivory White Coffee Tartufo Black Ivory White/Navy Blue Fineline Stripe Wood High Gloss trim is standard. Available alternative trim finishes include: Aluminum Tetragon Aluminum Dark Mesh Brown-Metallic Ash Grain Wood Fineline Stripe Brown High Gloss Wood Anthracite Brown Poplar Matte Finish Wood Live Cockpit Professional with iDrive 7 and new BMW Maps The standard Live Cockpit Professional in the BMW X5 xDrive45e brings the latest-generation of BMW’s iDrive interface and is composed of a high-resolution digital 12.3” instrument cluster display behind the steering wheel and a 12.3” touchscreen center display. The system offers haptic controls for the iDrive controller, an advanced tablet-like touch interface, stunning visualizations and the largest displays in BMW’s vehicle lineup. iDrive 7 in the X5 xDrive45e includes standard navigation with new BMW Maps, a digital cloud-based feature which offers faster route calculations and dynamic recalculation based on precise real-time traffic data. The route is worked out using an anticipatory approach, meaning upcoming traffic along the entire route is factored into the calculation of the expected arrival time. Complete traffic data is now available for less-traveled roads, too. Hazard warnings transmitted online from the BMW fleet now reach the car even faster thanks to connected navigation. These improvements help to produce a very accurate estimate of arrival time and improved route guidance. The destination input function has also been improved and now lets the driver enter any word. Alternatively, the destination can be entered at any time simply by voice control. Plus, points of interest (POIs) along the route are described in greater detail, with reviews, opening times and photos. Other elements of the BMW Live Cockpit Professional are two USB-C ports, plus Bluetooth interfaces. The vehicle can automatically detect the driver and his/her personal settings by either using the traditional vehicle key or by downloading the driver’s personal settings in the BMW Cloud. Drivers can enjoy the full benefits of the car’s intelligent connectivity capabilities through vehicle apps such as news, weather, office and online search. Apple CarPlay and Android Auto Compatibility The new 2021 BMW X5 xDrive45e offers standard wireless Apple CarPlay and Android Auto compatibility. Google Assistant, Google Maps, music streaming services like Spotify and Amazon Music and the WhatsApp messaging service are now available to both iPhone and Android users. Driver Assistance Systems The 2021 BMW X5 xDrive45e is available with a wide variety of standard and optional driver assistance systems. The systems relieve strains on the driver in monotonous situations, such as traffic jams, or when driving long distances. The driver assistance systems process camera images as well as the data gathered by ultrasonic and radar sensors to monitor the vehicle’s surroundings, warn of potential hazards and minimize the risk of an accident with corrective braking or steering inputs. The standard Active Driving Assistant on the new BMW X5 xDrive45e includes Blind Spot Detection, Lane Departure Warning, Rear Collision Warning, Frontal Collision Warning and Pedestrian Warning with City Collision Mitigation (which now also alerts the driver if cyclists are detected) Cross Traffic Alert Rear and Speed Limit Information. The optional Driving Assistance Professional Package offers comprehensive assistance for comfortable and safe driving. This package includes Active Cruise Control with Stop & Go function. It can be used at speeds up to 130 mph and maintains the desired speed while taking the traffic situation into account and the selected distance to vehicles in front. If required, the system is able to brake, stop the car and pull away again automatically after being stationary for up to 30 seconds, meaning greater comfort in stop-start traffic. Camera images and data from a front radar system are used for distance control. Another component of the Driving Assistance Professional Package is the Lane Keeping Assistant with Active Side Collision Protection. This system is designed to help the driver guide the vehicle back on to the correct path with an active turn of the steering wheel. Besides emitting visual warning signals and causing the steering wheel to vibrate, Active Side Collision Protection also uses active steering intervention to help avoid a collision. Moreover, this package includes Extended Traffic Jam Assistant for limited access highways, which allows for even more relaxed driving at speeds lower than 40 mph during highly congested highway traffic situations. The Driving Assistance Professional Package includes Evasion Aid, which now also reacts to pedestrians, and Front Cross Traffic Alert – which reduces the danger of a collision when maneuvering toward roads that are obstructed from the driver’s view. The drive recorder, a new feature on the optional Parking Assistance Package, uses the cameras of the various driver assistance systems to record video footage from the front and/or rear view points of the vehicle before storing the recordings. The saved video files can be either watched later on the center control display when the car is stationary or exported via the USB port. When activated, the drive recorder shoots and stores up to 40 seconds of video. In the event of a collision, a period of up to 20 seconds around the moment of impact is automatically recorded and saved. For 2021 X5 xDrive45e Ordering and Pricing Guides see: https://g05.bimmerpost.com/forums/sh....php?t=1727830 For full technical specs see: https://www.press.bmwgroup.com/usa/a...tivity-vehicle
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
06-11-2020, 09:09 AM | #2 |
Rep 136
Drives: X5 45e M Sport
30 mile range?!
Current: 2022 G26 i4 M50
Previous: 2020 G05 X5 45e MSport, 2016 F15 X5 30d MSport, 2015 520d M Sport, 2013 320i Sport |
Kr0m3assass1n1094.00 |
06-11-2020, 09:53 AM | #4 |
Rep 775
This in M sport trim would be amazing. I think people forget just how fast 0-60 in 5.3 seconds is.
2008 997TT 6-Speed - stock (for now, just enjoying)
2019 Audi S5 Sportback JB4 equipped - mommy mobile 2011 X5M - daily family hauler 2010 Toyota Prius - stealth mobile 140K miles since new and still 45 MPG 2017 Lexus GX460 - (gone) - easily one of the most reliable cars I?ve ever owned 2014 328i xDrive M-Sport - 270 WHP w/JB4 (gone) 2010 BMW 535i RWD - 400 WHP (gone) 1992 R32 Nissan Skyline GTR 500 WHP (gone) 1993 Toyota Supra TT 6 speed - 500 WHP (gone) |
06-11-2020, 10:07 AM | #6 |
Rep 4,437
Drives: 2022 iX xDrive50, DGM
On the Ordering Guide it shows Android Auto as an option - not standard. ????
06-11-2020, 10:08 AM | #7 |
Bimmer without rage
188
Rep 87
Drives: 2022 X3 M40i | 2020 X5 M50i
I thought the 45e in Europe has at least 50-60 miles range???
Unless it's kilometers and I remembered it wrong??
06-11-2020, 10:11 AM | #8 |
Rep 62
It's advertised as 52miles in the UK and I get about 40/45 miles from mine on pure electric.
06-11-2020, 10:13 AM | #10 | |
Bimmer without rage
188
Rep 87
06-11-2020, 10:20 AM | #11 |
5854
Rep 10,232
The electric only range could be good enough for the majority of grocery, mall, and dry cleaning visits.
06-11-2020, 10:21 AM | #12 |
///M
6649
Rep 3,683
I guess it's ok for people that have short drives.
Double the range would fit most people needs.
Life is too short...enjoy your life
///M |
06-11-2020, 10:24 AM | #13 |
Rep 67
I mean if you drive around town or city driving that EV mileage is fine. Plus if you look at other PHevs that are currently out, thats about the average mileage. Definitely an uprade from the 40e. That 4 cylinder hybrid combo for the x5 and 7 was a joke.
2019 X5 40i (current)
2020 330i (current) 2017 i3 (Sold) 2005 M3 6MT (Totaled) 1997 M3 Vert (Sold) |
06-11-2020, 10:41 AM | #15 | |
kr0m3assass1n
1094
Rep 858
Drives: 22 X7 M50i
I'm just shocked that 5+ years after that initial version, they only increased range by a paltry 15 miles. Real world usage with heating/ cooling and other electrical systems means this thing will truly only get 60-70% of the stated range. |
06-11-2020, 11:12 AM | #17 |
Rep 183
30 miles seems very low for it to be rated at, alltough I know numbers are different in US vs europe.
Here it is rated at 88 km. In practice I am getting a mileage of around 60-70 kilometers depending on drive mode and temperature. That should be achievable in the US too, albeit divided by 1.6something the become miles :-) |
06-11-2020, 11:32 AM | #19 |
Rep 1,367
For people complaining about range, it is a hybrid, not a full electric. Yes you have some pure electric mileage, but the main point is to increase gas mileage, so you can average 40mpg instead of 30mpg. If you want a full electric and more range, buy a Tesla.
2020 Porsche Cayenne E Hybrid
2018 X3 M40i 2017 Audi S6 (sold) 2015 BMW X5 xDrive35i (sold) 2015 BMW X3 xDrive28i (sold) |
06-11-2020, 11:36 AM | #20 |
Rep 774
Am I the only one thinking the numbers/letters name conventions are getting a bit much? It's called the X5 xDrive45e PHEV? Is this the ultimate driving machine or all in one copier fax machine? /rant/
06-11-2020, 12:31 PM | #22 |
Rep 4,210
