06-20-2020, 08:54 AM | #1 |
Rep 1,198
M50i "true" exhaust tips - install w/ pics & measurements
I won't take you through the embarrassingly long process this has been, or the FOUR different sets I've ordered..... or the 3 companies that screwed me and took weeks to provide a refund..... or the first set I ordered before I even took possession of the car, that didn't fit right because the measurements were wrong, so one of them fell off while driving. All in all, this has been a 5-month ordeal for me.
Exhaust tips on an M50i are NOT just a matter of "finding the right size". First things first...... the final product. I'm QUITE pleased with it. The measurements are SPOT-ON, and I love the way it looks. If you want to see what I had to do to get it..... keep reading.
12+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019 690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813 6-Piston X5M Big Brake Kit:https://g05.bimmerpost.com/forums/sh....php?t=1779038 Last edited by Ninefourteener; 07-04-2020 at 10:00 AM.. |
06-20-2020, 08:55 AM | #2 |
Rep 1,198
First things first..... the problems.
1) the exhaust hangs too low, and isn't centered between the top and the bottom of the exhaust shroud. 2) what EXACTLY are the right size tips that will fit through the exhaust shroud without rattling? Let's start with problem #1: While the OEM exhaust hangers are the right length from post to post..... they stretch. They are 38mm when compressed, but when stretched.... they are nearly 50mm..... which is why the exhaust hangs too low. My car only has 5000 miles on it, so even new, they stretch considerably. Last edited by Ninefourteener; 06-20-2020 at 10:03 AM.. |
Addbuyer826.50 Thewolfbmw215.50 |
06-20-2020, 08:56 AM | #3 |
Rep 1,198
So the solution...... was these grimmspeed hardened poly exhaust hangers. Also 38mm from post to post...... with a 12mm post hole. Although, I believe the OEM BMW posts are 10.5mm. 12mm holes worked fine though.
These however..... will not stretch like the OEM rubber hangers. Notice that they look exactly the same when weighted (not stretched)... and after installed, they center the pipes nicely between the top and bottom of the exhaust shroud. Last edited by Ninefourteener; 06-20-2020 at 10:05 AM.. |
06-20-2020, 09:10 AM | #4 |
Rep 1,198
Now...... what size tips to buy?
The OEM exhaust pipe size is 60mm, or 2.36 inches. I ended up buying a 57mm ID (2.25") tip...... but then stretched it with a pipe expander The OD of the exit of the tip can be NO MORE than 3.1 inches... MAX. Otherwise, the tips will contact one another. The overall length.of my tips was 6 inches. Had I purchased 60mm/2.36" inlet tips, I could have squeezed them on a little further..... maybe 1 inch. The length.of the tips.can be NO MORE than 7 inches. Last edited by Ninefourteener; 06-20-2020 at 09:57 AM.. |
Addbuyer826.50 |
06-20-2020, 09:15 AM | #5 |
Rep 1,198
Now.... because I was only able to get the tips on the pipe about 3/4 inch...... I welded instead of clamped.
Also..... I noticed that when I safety-wired my exhaust flapper valves open about a month ago, one of them had developed a slight rattle. Might as well weld that permanently too. |
Addbuyer826.50 PablitoX7m3.50 |
06-20-2020, 09:20 AM | #6 |
Rep 1,198
Last post..... So here's what you need:
1) 2x hardened poly exhaust hangers, with a 35-38mm distance between holes, and 10.5mm holes. 2) 4x exhaust tips Inlet ID 60mm or 2.36 inches (exactly) Oulet OD 79mm or 3.1 inches (max) Overall length 5.5 to 7 inches 3) A welder 4) Patience. Good luck. Thanks for reading. Last edited by Ninefourteener; 07-04-2020 at 09:48 AM.. |
06-20-2020, 10:03 AM | #7 | |
Rep 242
Also I think it would look sharp if you had the lower bumper wrapped in gloss black or white instead of the dark grey. |
hunternight542.00 |
06-20-2020, 10:14 AM | #8 | |
Rep 1,198
Clamps would work..... but I'm telling you, I had a hard time getting a stick welder in there. Trying to reach clamps with tools would be a nightmare. Your best bet, is to do an eBay/Amazon search, for 60mm or 2.36 inch exhaust tips. (2.36" seems to be unique to BMW). Then, scroll through and find one with a 3-inch OD..... then make sure it's no more than 7" long. Most tips with the right ID..... will be a 3.5" exit OD. That is too large. They won't fit through the exhaust shroud. Be careful...... read descriptions closely. Here is an example of a PERFECTLY sized tip..... but it's not the color you want. They DO exist.... you just have to read the descriptions carefully, and put some effort into searching for exactly the "look" you want. Too many choices, colors, styles, manufacturers to choose from to link a specific one. The measurements are what is important. https://www.ebay.com/itm/Chrome-Car-....m46890.l49292 I actually removed the white diffuser panel and installed an OEM black one..... because I didn't like the way the hitch stood out as a "black hole" in the middle of it. That was intentional. I am considering having both the diffuser and the upper bumper panel repainted in gloss black though, to match the shadow line trim. Last edited by Ninefourteener; 06-20-2020 at 10:33 AM.. |
06-20-2020, 01:29 PM | #9 |
Rep 444
All that determination has paid off, it looks the dogs. I just don’t understand why BMW have made the standard M50i’s tips look so pathetic Of course the X5 Comp has to look the nuts but why the huge cavern between the M50i and the Comp
06-20-2020, 01:36 PM | #10 | |
Rep 1,198
I actually considered removing the exhaust shroud entirely, torching the pipes, separating them, and going with a set of 4" tips..... but that would be irreversible. And, I actually don't think it would look right with that style of bumper anyway. Figuring a way to get tips to stick "through" the existing shroud..... without rattling on the shroud itself, was my goal. It worked |
06-21-2020, 05:08 AM | #11 | |
Rep 444
60 x 76 x 160 https://www.aliexpress.com/item/32810362529.html Or https://www.ebay.co.uk/itm/153970645...&ul_noapp=true Last edited by Addbuyer; 06-21-2020 at 05:25 AM.. |
UltraDave127.00 |
06-21-2020, 05:51 AM | #12 | |
Rep 1,198
That carbon set... also says "3.5" in the title.... but 3-inches in the description. I don't trust the Chinese, so be sure of what you are buying. 3.5 OD exit is too large. Also...Don't forget though.... you need a 35-38mm set of hard polyurothane exhaust hangers. If you install those tips with the exhaust hanging low and wobbly like it does from the factory, they are going to wobble, rattle, and possibly break off. |
06-21-2020, 06:12 AM | #13 | |
Rep 444
For anyone who hasn’t got access to a welder or is nervous about using one then there’s always liquid metal which gives great results and would allow plenty time to adjust the tips before they sets. |
06-21-2020, 06:44 AM | #14 | ||
1044
Rep 1,943
Also, does anyone have experience with AliExpress and shipping to US? Nervous dropping $200 bucks on them since I've never used them. |
06-21-2020, 08:58 AM | #16 | |
Rep 444
06-21-2020, 09:28 AM | #17 | |
Rep 242
06-21-2020, 10:09 AM | #18 | |
Rep 1,198
I chose to weld, because my fitment was so tight. My tips were 57mm, and I stretched them to 60mm, but I was only able to get them on about 3/4 of an inch. Technically, I bought the wrong size. But, it was the 4th set I bought, and I wasn't about to go through that again. I made them work. Had I bought the right size (60mm)...... I would have been able to slide them on considerably further. I would not have needed to weld. A clamp would have been just fine. Admittedly though, tough to reach with tools. |
06-21-2020, 11:53 AM | #19 | |
Rep 444
Failing that and for anyone who might want some without logo etc, maybe this seller is worth messaging? https://www.ebay.co.uk/itm/AKRAPOVIC...YAAOSwc1BetDql |
06-21-2020, 01:15 PM | #20 |
Rep 1,198
I don't know that other models use the same size exhaust tubing. This post was specific to the M50i. 40i cars, 30i cars, and maybe even standard 50i cars may have completely different sizing.
08-16-2020, 03:35 AM | #21 |
Rep 444
Having had the resonator and secondary cats removed, I am now looking at improving the looks i.e. this exhaust tip mod. Luckily I measured the existing first and mine are coming in at 64mm
08-16-2020, 07:11 AM | #22 | |
Rep 1,198
Remove the panel (it's only 6 or 7 8-mm bolts if I recall, and use a precise measurement tool to measure the actual diameter of each pipe. Perhaps there were differences in various models? Either way, don't buy anything until you've done an accurate measurement from underneath the car with a digital tool. |
