06-22-2020, 03:34 PM | #1 |
Rep 1,368
M2 M Performance Suspension and Vorshlag Camber plates - which one?
https://vorshlag-store.com/collectio...32106773610558
Honestly, I am a little confused - I know it is a 5-bolt but what strut type is it? I just checked the top nut and its not 19 or 22 - an 18mm multi-point socket felt like it fit the best. Anybody have these cambers and can provide a suggestion on the specific strut type to select? Thanks Last edited by lax01; 06-22-2020 at 03:40 PM.. |
06-22-2020, 04:30 PM | #2 |
Rep 1,368
I just went and measured the strut shaft and the top nut is also a 10mm (not 12 or 14mm) so now I'm really confused...would Vorshlag potentially be able to answer this question?
06-22-2020, 04:52 PM | #3 | |
846
Rep 1,962
06-22-2020, 04:57 PM | #5 | |
Rep 1,368
Never had a problem with them though The shop who is doing the install asked as they are going to acquire the camber plates |
06-22-2020, 05:28 PM | #6 |
Rep 1,094
You could probably look in the MPS installation guide to see if the OEM nut gets reused.
Edit: hm, not easily found Last edited by mr_lab_rat; 06-22-2020 at 05:37 PM.. |
06-22-2020, 05:39 PM | #7 |
Rep 1,368
hah, well I did find it and I believe there was an "optional" hardware kit for it? I honestly don't know...I have a M2 Performance Edition and the suspension was all port-installed
06-22-2020, 10:41 PM | #8 | |
Rep 140
Stock suspension has 18mm 12 point like what you have in the picture, then the M perf suspension kit comes with 22mm 6 point nut replacement. |
06-23-2020, 05:27 AM | #9 | |
Rep 4,522
https://rparts-sites.s3.amazonaws.co...ll%20instr.pdf Page 4 shows parts list - items K thru Q are the extras required for install . K Nut M10-10-ZNS3 (2 x) (not included in the parts kit) L Hexagon screw M10x10 80-U1-10.9 (2 x) (not included in the parts kit) M Gasket (2 x) (not included in the parts kit) N Combination hexagon screw M8 x 33 10.9 ZNS3 (10 x) (not included in the parts kit) O Collar nut M14 x 1.5-05 ZNS3 (2 x) (not included in the parts kit) P Combination screw M12 x 125 -10-ZNS3 (2 x) (not included in the parts kit) Q Bihex nut M14 x 1.5 ZNNIVSI (2 x) (not included in the parts kit) OEM part no. for item O above - front strut top nut - is 34339806226 HTH, BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
06-23-2020, 09:38 AM | #10 |
Rep 1,368
So, the port didn't install with the optional hardware kit? Whats the impact? Whats the purpose of the optional hardware kit?
Also, not really helping me with my real question in this thread hah - what is the strut type for Vorshlag camber plates? |
06-23-2020, 10:50 AM | #11 | |
Rep 140
For me though, i just used the hardware that came with the kit, which was 22mm. As far as your original question, it's probably best if you just email them directly. |
06-23-2020, 11:00 AM | #12 |
Rep 1,368
hah - yeah, gonna call over there - I also realized I was looking at the wrong camber plates: https://vorshlag-store.com/collectio...13539286941758 (is the correct one - for anyone in the future)
But it doesn't help clear up the question: I'm not sure where Vorshlag got the 19 and 22 top nut numbers...I've seen nothing in research to indicate that the top nut is either size |
06-23-2020, 11:02 AM | #13 |
Rep 1,368
06-23-2020, 11:11 AM | #14 | |
Rep 140
the stock suspension has 18mm that looks just like yours. |
06-23-2020, 11:21 AM | #15 | |
Rep 1,368
Do we know if the M Perf. Suspension came with a 19mm nut too? Haha |
06-23-2020, 01:05 PM | #16 |
846
Rep 1,962
I take it back - having gone and looked at mine again.
The black 'nut' is the hex on the top of the shaft, with the BMW locknut on the threaded section below. The F22 - i think - uses the smaller diameter damper rod with an M12 nut, while the M2 uses M14. I'm fairly sure I saw a picture where someone was trying to fit incompatible parts and used a couple of washers to make it work. I got mine in 2017. It came with Nyloc nuts for the strut. I used the BMW items instead. |
06-23-2020, 01:31 PM | #17 | |
Rep 1,368
06-23-2020, 01:57 PM | #18 |
300
Rep 379
OEM - the MPS is meant to be installed with the OEM strut. I ordered Ground Control - OEM strut type for my MPS.
BMW CCA and PCA HPDE Instructor
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022 |
06-23-2020, 02:04 PM | #19 | |
846
Rep 1,962
If I notice uneven wear on the front without tracking problems I would probably follow Bee Pee and fit the .5 degree hubs. |
06-23-2020, 02:07 PM | #20 | |
Rep 1,368
06-23-2020, 02:11 PM | #21 | |
Rep 1,368
Assuming you are talking about this thread: https://f87.bimmerpost.com/forums/sh....php?t=1480788 |
gphung193.50 |
