06-24-2020, 10:11 AM | #1 |
14
Rep 38
F34 tires dilemma
I recently bought a used 2016 328i GT x-drive with the M sport package. While on an 8 hour trip I had one of my rear tires separate so I am looking for new tires. Before I bought this F34, my previous car was a 2015 328i (not GT and I don't think x-drive) and it seemed to have a smoother ride. My current F34 has the run flat tires (all four are 255/50/18)and I'm wondering if I should stick with run flats or try a different tire that would feel smoother. I see the posts about the Michelin Pilot 4S and I was ready to pull the trigger on it, but after reading a lot of reviews I'm not sure that's what I need. I don't drive my car like a race car. I live in the panhandle of Florida so winters aren't harsh at all. I almost always drive in comfort mode and only switched to sport mode a couple of times to pass somebody and make a statement lol. Maybe it's not the tires that need to be switched and maybe it's an alignment or a shock issue. It's not terrible, but I feel like it should be smoother coming from an F30. Any suggestions for a smooth ride tire and not necessarily a tire that's ready to race in nascar? And if the Michelin Pilots 4S or 3+ is supposed to be a smooth ride and not just a performance tire, then I might go with that. I know it's a trade off not to have run flats because having the tire separate did allow me to continue to drive to a tire shop in the middle of nowhere to get the only tire they had in my size in Magee, MS. I keep going back and forth and thinking also maybe I should stay with run flats and see about my shocks and wheel alignment. I hate decisions...
06-24-2020, 10:55 AM | #2 |
5886
Rep 10,256
Couple of questions about the current tires:
- How many miles did the rear tires accrue before the tread separation? - Brand / model? Non run flat tires will improve the ride but will also change how tires respond to sharper turns since the sidewall is softer. It's difficult to get better non run flat tires than Michelin Pilot 4S. If you prefer the convenience of run flat tires, Bridestone Potenza S001 are harsher than others. I like Pirelli P Zero run flats (second set already). These are not perfect but much better than Bridgestone. Last edited by cfm56d7b; 06-24-2020 at 12:17 PM.. |
06-24-2020, 10:57 AM | #3 |
5886
Rep 10,256
One more item.
Since you recently purchased your car, I suggest to inspect shocks, springs, and learn from the previous owner when the last wheel alignment was done before considering any suspension changes. |
06-24-2020, 11:06 AM | #4 | |
14
Rep 38
06-24-2020, 11:07 AM | #5 |
14
Rep 38
I will take it and get the shocks, springs, and alignment checked. Thank you for your info!
06-24-2020, 12:09 PM | #6 |
Rep 177
I'm on the same boat as you... with the factory 400M wheels and the Bridgestone Driveguard 225/50/18 RFTs that came with the car. I don't mind the ride on them so much, and they still have <50% tread left. But I want new 19" wheels and I will definitely not buy RFTs for that. On my previous E90 335i, I remember switching from RFTs to regular Conti DWS06 and Vredestein Quatrac... the difference in noise and comfort was tremendous!! I also have Michelin Pilot AS3+ on my E60... and those are great tires too, very responsive.
If you do take road trips a lot, you may want to invest in a 'spare tire kit', and definitely sign up for emergency roadside assistance for that extra peace of mind. |
bnsparker13.50 |
06-24-2020, 01:48 PM | #7 |
8243
Rep 16,082
You need to have a tire repair kit and pump onboard, period. I've had to fix two punctures in the last two years, both happened within a few miles of home. If you do road trips get an emergency spare to carry with you. Expensive, but cheaper than a flatbed ride.
bnsparker13.50 |
06-24-2020, 02:23 PM | #9 |
8243
Rep 16,082
That's fine if you're not on a schedule. When I'm headed out of town it's because I'm going to an event, and I can't spare the time for a tow and a fix. I can patch my own in 20 minutes, tops. Before the GT I had to think hard about when I last got a flat, and in the end couldn't remember. Maybe 1973. But two in the last two years made me a believer in the Boy Scout Motto.
wilbur_the_goose353.00 |
06-25-2020, 08:38 PM | #10 | |
Rep 6,031
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner |
06-25-2020, 09:32 PM | #11 |
8243
Rep 16,082
I have RFT's, still carry my fix it stuff locally and a spare for out of town trips. If you fix an RFT puncture immediately it's no big deal. If you drive on it once the air is gone and you're riding on the inner sidewall the tire is permanently damaged and must be replaced. My $20 worth of tire repair tools have saved me around $400 by not having to replace the two tires I fixed.
KRS_SN13531.00 wilbur_the_goose353.00 |
07-08-2020, 07:54 PM | #12 |
14
Rep 38
So I ended up deciding to ditch run flats to see if my ride improved. I ended up going with Yokohama YK740 GTX tires and I got some new wheels so I will also have a full size spare for my car and my daughter's BMW since neither had spares before. I also did get an alignment and had the suspension checked and it's all good now.
I have to say...it's definitely smoother now without the run flats. I don't drive it like I stole it like maybe I should, being a 42 year old woman who some would say is going through a mid-life crisis. I painted my calipers too. 😉 Don't hate! I know a lot of people are dogging folks that paint their calipers red, but I like it with the white car and black wheels look. I'm happy now with the wheels, tires, and smoothness of the ride. Now I just have to figure out how to fix my hatchback to make it open without an initial boost and wrap my scratched up interior m sport molding. I'm making progress! Thanks for all of your input about run flats! |
