06-24-2020, 10:15 AM | #1 |
14
Rep 38
F34 M sport interior silver trim looking rough
I bought a used 2016 328i GT with the M sport package and I love the look except for the light silver interior trim looks rough in mine. It's flat instead of glossy and I guess the previous owner was rough on the inside so it's all scratched up and looks bad especially around the gear shift. Has anybody switched out or replaced the interior trim pieces (around gear shift, one on each interior handle, and the piece below the dash). If so, where can I find them and what color/look did you go with? Thanks
06-25-2020, 03:29 PM | #2 |
Rep 177
Wrapping it with some sort of carbon fiber vinyl seems to be the popular choice and also cost effective. I have the same 'brushed aluminium' trim and like it... seems to brighten up the otherwise dark black interior.
06-25-2020, 11:56 PM | #3 |
14
Rep 38
I would like it if it wasn't so scratched up. The previous owner must've been super hard on it for it to look so bad in mine.
06-25-2020, 11:59 PM | #4 |
14
Rep 38
Thanks. I will google wrapping it. I wouldn't mind replacing it with it the same (but new) if I could find it. I've looked online but I can only find the pieces in a dark grey carbon set.
06-26-2020, 03:36 PM | #5 | |
Rep 109
https://www.google.com/search?q=site....com+trim+wrap just have to do a bit of DIY and practice to get it shaped/stretched/trimmed right |
bnsparker13.50 |
07-03-2020, 12:57 PM | #6 | |
Rep 3
Carbon fiber cover is an option
bnsparker13.50 |
07-03-2020, 02:02 PM | #7 |
8243
Rep 16,082
With practice there's almost nothing that you can't wrap.
https://billfitzmaurice.info/images/BMW/Console.jpg If you get tired of it or it wears you can remove it and do it again. |
07-12-2020, 11:09 AM | #8 |
Rep 7
Just did the carbon fiber wrap... It wasn't as hard as I thought and just a little took time to do, so its was as perfect as possible..
My fingers hurt quite a bit after and I'd say it took me 5 hours of actual work total. Very forgiving material makes it a breeze... Hate to admit, but I found a quality roll at Autozone and bought 2. I don't normally condone any kind of AZ materials but its consistent and available if anything happens. I didn't want to wait for shipping and was bored... Very happy with the results..... Zero air bubbles but a little bit of delam* around the driver side air vent which just needs to be hit with some more heat.... Good luck... Again, looks rad!!!! Impressed with the upgrade..... I tried to get the direction of the Carbon Fiber to match as much as possible. Play with it before applying it to have things look semi-uniform. |
09-13-2020, 05:31 PM | #11 |
8243
Rep 16,082
Tutorials I've seen don't mention what I've found to be the best heating method. I set my low power heat gun in a bracket atop my work bench, and leave it running. I hold the work in one hand, wave it across the heat stream to get the wrap just warm enough to stretch, then use the other hand to stretch it into place. I work very small sections, no more than a couple of inches. This is much faster and works better than holding the work in one hand, the heat gun in the other, then putting the heat gun down before you can do the stretching.
bnsparker13.50 |
08-27-2022, 02:00 AM | #12 |
I make videos for all things F34 !
55
Rep 40
I’ve had my trim replaced by the dealer…if you look on the inside of the door panel specifically, the trim is plastic welded from the back. Check out the images of the part below. You basically have to melt the tabs down from the inside to the door panel to mount the strip in place. As for the bottom part of the trim piece on the dash, I do not believe that BMW makes that part separately from the upper piece and is imagine it would be much easier to buy a new one than trying to unclip those two pcs.
https://www.turnermotorsport.com/p-2...uine-bmw-part/ |
BimmerBren108.00 |
