BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Ista vs carly
      07-15-2020, 08:01 AM   #1
sollomon
Drives: M4,M5,M8C,X5M50I, X5M
2020 BMW X5M50I  [0.00]
2020 Bmw m8 competi ...  [0.00]
2018 BMW M4  [0.00]
2018 BMW M5  [0.00]
Ista vs carly
which result should i listen to?
BMW ISTA says 1-2 code
CARLY says over 100
      07-26-2020, 10:38 AM   #2
BMWM12045
Drives: F90 M5 C, F87 M2 CS
I drove the car exceptionally hard one day and I threw the codes 152D08 and a 14401D (0 mechanical sympathy.) Stock 2019 M5 C with around 4500 miles at the time
I took the car in to get checked out, had the oil changed, dealer cleared the code and said maybe it was just bad gas.
I never really drove the car that hard again but... I ended up with an actual engine knock noise ~3000 miles later. Dealer replaced the full engine. Found bearing metal in the oil. Not sure if it was related but maybe be careful with this?
m5post
