      07-17-2020, 06:06 PM   #1
IND-Distribution
IND-Distribution's Avatar
10214
Drives: G82 / G87 / G90
IND | F95 X5M Painted Front Reflector Set Install Guide
Tools Required:
  • Floor Jack and 17mm Socket
  • 8mm socket
  • Pry Tool
  • OEM plastic rivets (4x) – 51 77 7 171 004
  • Rivet Gun
Difficulty (1-5): 1
STEP 1: Loosen Lug Bolts
STEP 2: Jack up car and place jackstand
STEP 3: Remove Lug Bolts and wheel
STEP 4: Pull fender arch flare out and up from front bottom edge
STEP 5: Continue to pull out the front half of the fender arch
STEP 6: Remove 12x 8mm bolts holding the front fender liner in as well as 2x 8mm bolts attaching the brake duct to the liner. (Passenger side has 1 LESS 8mm bolt holding the liner in)
STEP 7: Remove the front fender liner
STEP 8: Pry off the 2 plastic rivets holding on the lower bumper bracket. The top rivet may be more easily accessed from the back
STEP 9: Remove the bracket by pressing in the tabs clipped into the bumper cover
STEP 10: Remove 3x 8mm bolts holding on the upper bumper bracket and unclip the bracket from the fender
STEP 11: Separate the corner of the bumper cover and the inner brackets to expose the back of the reflector
STEP 12: Use a heat gun to soften the adhesive, be sure to keep it moving to avoid burning the paint
STEP 13: Starting at the bottom, use your thumbs to press in the reflector until it separates from the bumper cover. Use spreading tool to help separate the adhesive
STEP 14: Once removed, be sure to remove any adhesive from the inside of the bumper cover that didn't come off with the reflector
STEP 15: Peel the tape to expose the adhesive on the painted reflector and reinstall
STEP 16: Press all around the reflector from behind to secure the adhesive
STEP 17: Installation is the reverse of removal. When reinstalling the lower bracket, use 2 new plastic rivets and a rivet gun
Appreciate 4
Simple1140.50
BMW003E962.00
      10-20-2021, 01:58 PM   #2
halfbent
Peanut Butter Jelly Time
India
23
Drives: 2014 Audi R8
What if you don't have a rivet gun?
Originally Posted by IND-Distribution View Post
Tools Required:
  • 8mm socket
  • Pry Tool
  • Rivet Gun
Difficulty (1-5): 1
      10-20-2021, 02:27 PM   #3
IND-Distribution
10214
We sell the rivet gun and pry tool kit to complete this installation if you do not have your own.
      10-23-2021, 10:04 PM   #4
Roch M4
I /// M FAN
435
Drives: M4 SS/SO 2016 / X5M C 2023
As my G05 is black, I will just add a black film over the reflectors, thank you for this procedure, but it's quit long and removing the plastic around the fenders is not that easy as you can easily damage them
      10-25-2021, 11:07 AM   #5
Burnt C6
Burnt C6's Avatar
281
Drives: 2025 X3M50i
I've been looking for these for my 2020 X6 but can not find them. any one got a line to where I can buy them painted?
I found them on your web site & Ordered.
Thanks
2024 X3 M40i. wife says no Mods since it's aLease.. I see a JB4 tune in the near future.
2014 328i Melbourne Red Sport Line Dinan Dinantronics tune,
Dinan Exhaust, Dinan Suspension, H&R Sway bars, 18x9 APEX PS-7 ,AFE CAI, BMW M Performance Brakes Retired
      10-25-2021, 11:28 AM   #6
IND-Distribution
10214
Thanks
X6/X6M do require a different core reflector and can be found at the link below for easy access to our website. Installation process shown in the guide is similar though!
https://ind-distribution.com/product...2ceb2cd5&_ss=r
Burnt C6280.50
      10-25-2021, 11:33 AM   #7
Burnt C6
Burnt C6's Avatar
281
Drives: 2025 X3M50i
that's the ones I picked up. You guys looking into front lips and rear diffusers for the G06. I can't seem to find anything. Well there is that Russian company but their prices are way over the top.
      10-25-2021, 11:45 AM   #8
IND-Distribution
10214
We are not producing anything in house, and we are not currently aware of anything to market for the G06.
BMW isn't producing any M Performance parts for the G06 at this time either.
Burnt C6280.50
      10-25-2021, 06:43 PM   #9
Roch M4
I /// M FAN
435
https://g05.bimmerpost.com/forums/sh....php?t=1869476
5$ Reflector delete
      11-04-2021, 03:57 PM   #10
Burnt C6
Burnt C6's Avatar
281
Drives: 2025 X3M50i
front ones came in today, look good. I now have enough bubble wrap to protect a small TV. LOL
great job on your guys packaging and shipping.
      11-04-2021, 07:26 PM   #11
JimVR4
JimVR4's Avatar
Drives: 21 X5 M50i M-Sport
5$ Reflector delete
You do realize you're posting in a vendor thread! Probably should delete from here.
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50
      11-04-2021, 08:57 PM   #12
Roch M4
I /// M FAN
435
You do realize that we are all adults here, able to decide what is best for them or no...they can choose for a simple mod or a complicated one
      05-28-2022, 08:51 PM   #13
TexanDiesel
Drives: X5M Competition
Is there any easier way to do this? I bought these without looking at the install videos thinking it’d be simple but I don’t have half the tools and am definitely going to f**k this up.
