07-19-2020, 06:51 PM | #1 |
36
Rep 46
My dash glare prevention solution
When driving in certain directions during a sunny day, there is an uncomfortable glare from two horizontal trim pieces on the dash.
To minimize the glare, I installed two strips of matte finish pin striping, which helps a lot. |
07-21-2020, 11:38 AM | #3 | |
54
Rep 42
I've been wanting to do something like that but didn't know where to start. What product did you use? |
07-21-2020, 04:12 PM | #4 |
Rep 477
One of the things I really like about the F30 is how the iDrive screen is never hard to read, even in bright sun. On my G20 test drive I noticed this reflection right away. Surprised they didn't correct it before release.
07-21-2020, 09:41 PM | #6 |
36
Rep 46
Trim Material
The adhesive backed material comes in a roll. It's matte black color, "Oracal 651 Intermediate Car Vinyl Matte," available at Michaels.com (and maybe in the store ?).
Cut the strips slowly and carefully with an X-acto No. 1 knife from Walmart or Michaels. Use a metal straight edge to make crisp and straight cuts on the material, and cut the ends to match the angle of the adjacent panel switches. I measured the surfaces that create the glare and cut the top strip a little wider than the bottom one. |
VipinLJ1944.50 |
07-22-2020, 10:28 AM | #7 |
Rep 285
BMW should not wait for LCI to fix trim issue.
There are really not much I would bitch about this car, but the Sun from the aft-starboard quarters does make center display and HVAC controls unusable while driving. |
07-22-2020, 01:40 PM | #8 | |
Rep 265
What is LCI? |
05-18-2021, 03:35 PM | #10 | ||
Rep 19
Alex
05-19-2021, 10:17 AM | #11 |
115
Rep 344
Drives: G20 330ix M Sport
That's a good idea.
"It is funny...people who drive anything expensive often get labeled by folks who drive less expensive cars. I have found, without exception, that douchebags cover all demographics and incomes."
05-21-2021, 01:41 PM | #12 |
Rep 1,479
Drives: 2020 M340Xi (G20)
@[Bud Weber]
Wow, talk about fortuitous! I was on my way back home yesterday and the sun kept hitting the center vent frame and put off a strong glare -- and like you and others have said, couldn't even read the iDrive! Well, I got home and later was looking through BimmerPost and saw your post. Went down to local Michael's and they had matte black on hand so I bought a small roll. I also measured; the top lip was 1/2" wide and bottom lip around air conditioner controls was 3/8" -- of course measured the length. I used a paper cutter. Hopefully next time I'm on the road that will do exactly what you have found! Thanks!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
VipinLJ1944.50 |
