07-24-2020, 04:43 AM | #1 |
1197
Rep 1,587
BMW Digital Key 1.5 (Apple CarKey) - the FACTS
I've seen a lot of speculation and misinformation on BMW Digital Key (DK) 1.5. Hopefully, this post will help clear some of the mist.
Digital Key DK is the technology used on the device. There are 2 versions: 1.0 - current version supported on Android devices and NFC card 1.5 - new version which supports the NFC card AND Apple Products ONLY DK 1.5 can only be enabled on supported iOS devices with version 13.6 and later. The latest BMW Connected Drive app is required. The CD account and associated car MUST be enabled for DK1.5 in the cloud service. This is done automatically at the back-end, not by dealers, presumably based on the cars VO build version. If DK1.5 is enabled for a CD account, then the DK option will appear in the app. Smart Access The car itself has what's called Smart Access (SA). Again, two versions - 1.0 and 1.5, which align protocol-wise with the DK. SA 1.0 is enabled on all applicable models equipped with Comfort Access, except where Smart Access 1.5 is used. SA 1.5 is enabled on all applicable models equipped with Comfort Access AND i-step 07/2020.25 and later AND the Vehicle Order (VO) build version in FA is July 2020 or later. If SA 1.0 is enabled on the car, then the idrive settings will display a menu called 'Activate Key' If SA 1.5 is enabled on the car, then the idrive settings will display a menu called 'Activate Main Key'. See attached pics of the menu To use the new BMW Digital Key Service you need BOTH SA 1.5 AND DK 1.5 So, what does this mean for owners with DK supported cars with a build version earlier than 07/2020? Will BMW retrofit? Not currently! As mentioned above, Android devices do not support Smart Access 1.5. If BMW were to retrofit this to existing models then it would break all Android devices DK support. What can BMW do to address this issue? 1. Just roll it out, break the Android service and refund the customers 2. Wait until all the Android subs expire and then roll it out 3. Google update the Android Car Key support to include the new DK 1.5 format/standard 4. Address each customer on an adhoc basis - nightmare as it would require different coding for each car. Apple need SA 1.5, Android users 1.0. 5. Leave as is. No retrofit. New customers get DK/SA 1.5 and support is for Apple Products only. Happy to refine this position as new information becomes available but the current message being delivered by BMW dealers is often plain wrong! A video has been referenced on these forums that was completely wrong, and has since been removed. I'm not claiming to have all the answers, but hopefully this post will have clarified a few points. Note: its probable that X series owners will not get the new service unless they have a 08/2020 production vehicle. Others 'should' get it if they have a 07/2020 vehicle. Last edited by ifr; 07-24-2020 at 04:49 AM.. Reason: typo |
26
Helius16.50 BBDDVV10.50 sward629.50 volodp193.50 CruiseControl215.50 iknowdjz108.50 Dataready15.00 thereef5101163.00 pho116.00 havenyoung59.00 mandomedic12240.50 TSMC55126.50 marcosg24.50 Cooltones241.00 OzJedi107.00 edtreo88.50 SmartSaves459.00 lumpydog690.50 GrussGott18113.00 GeniusAdam115.50 Farooqshaik9.50 BigMofoFrog179.00 fourplay0.00 SaNGRia980.00 antah16.50 kkpat44.00 |
07-24-2020, 10:51 AM | #2 |
83
Rep 343
I would also add that you also need a compatible apple device, as I mentioned in the other iphone Key thread. Here is the official documentation:
https://support.apple.com/en-us/HT211234#what-you-need |
07-24-2020, 12:17 PM | #4 |
Rep 4,447
07-24-2020, 01:02 PM | #5 | |
1163
Rep 1,773
you're right, its an extra method to negotiate your vehicle. but honestly nobody here is gonna use this regularly for the amount of outrage over which MY2020 builds will get or not get this feature. |
07-24-2020, 01:10 PM | #6 | |
Rep 143
In any case, it’s certainly more useful than a lot of other expensive options most of us (including me) order just because of the cool factor. Crystal shifter, sky lounge roof, ... |
thereef5101163.00 nighter0.00 |
07-24-2020, 01:32 PM | #7 |
Rep 110
Thank you for the clarification!
One other thing to mention: It is no longer possible to renew or purchase Digital Key 1.0 subscription through ConnectedDrive store. So it does seem that BMW might be taking the option 2. |
07-24-2020, 01:57 PM | #8 |
1197
Rep 1,587
I agree its not a great implementation. Barely a substitute for a key fob never mind a replacement, but early days.
With the key fob I never even think about locking/unlocking the doors. Keep it in the pocket or wherever, walk up get in, get out, walk away, done. The exception might be the AW5 which has promise, but I'm not clear if it can only be used to open the door and cannot be used to start the car. There is already coding for smart access 2.0, but not active. Let's hope that allows the extended range for communication. |
thereef5101163.00 |
07-24-2020, 03:10 PM | #9 |
Rep 74
I'll be curious to see if BMW continues to support the 2019/20 Android Samsung owners using DK 1.0.
I understand all the Apple users enthusiasm to begin to use your phone as key because it's very convenient and reliable once activated. No surprise to anyone here BMW's implementation, dealer education and renewal process was bit of a nightmare for some (all for a $20 subscription key renewal for year two). Switching between devices was sometimes a challenge too, hopefully DK1.5 solves some of the technical challenges and BMW knows how to manage the process. Now we just need the newer Android phones adopt the same standards so coverage is universal for all! |
07-24-2020, 03:30 PM | #10 |
Driver
161
Rep 447
Dumb question, but is there a hardware difference between DK 1.0 or is it just software/firmware that is updated? The answer will not change anything, as I don't plan on using a digital key on any type of device, but it will satisfy my curiosity. Thanks!
07-24-2020, 04:59 PM | #11 |
1197
Rep 1,587
Just software, at the car level at least.
07-25-2020, 07:12 PM | #12 |
Driver
161
Rep 447
Interesting. So I would imagine that BamW could just enable it at the back-end for older cars, and probably will once they figure out how much to charge for the process...
Or maybe they’ll be like most car manufacturers and just ask us to buy a new vehicle to get the features that were not originally sold with the car. It always strikes me as odd that car manufacturers aren’t really understanding the power of using their cars as software platforms. |
juhcobywankenobi36.00 |
07-25-2020, 07:24 PM | #13 | |
Rep 176
Drives: 2019 BMW 330i
BMW really needs to make their lives easier, have a steady stream of services and paid features for their cars and make them available to all. The current method of ad hoc configured builds where in a half year some cars have the feature and others don't is just a logistical nightmare. Keep it simple stupid is really a mantra they should implement. Manufacturer happy, customer happy. |
07-26-2020, 07:49 AM | #14 |
Rep 272
Now THIS is the most accurate, truthful status of Digital Key that I have read, thank you!
There is so much misinformation that it's going to be very hard for new and existing owners to keep their head straight with all of this. The challenge will be whether BMW will allow this for existing customers and which of the above options that they'll take. To be honest, I'm surprised they don't just offer a choice between 1.0 and 1.5 in the CD store and let us pick based on the devices we have. They'll make a pretty penny in the process. I think it might have to do with Apple and their disagreement for BMW to charge customers to use Apple services (which they want to keep free) They flipped out over CarPlay subscriptions and was the real reason behind BMW backflipping on it. |
07-26-2020, 08:08 AM | #15 |
Rep 647
BMW *might* be able to increase market share by adding future value to their vehicles by enabling things like digital key 1.5 to vehicles that can support that, even if there is a reasonable fee. Perhaps they can take some market share form MB and others on both new cars and used cars if they can roll out some features and not break other things in the process.
08-18-2020, 05:31 PM | #17 |
210
Rep 715
I have a working digital key for my M50i using a Galaxy S10+
I like the feature & hate to lose it. My question is I don't understand one thing: Dk 1.0 current implementation supports Android Dk 1.5 will support only Apple. Practically every technology I ever heard of has backward comparability. It makes no sense that the new version only supports Apple. Heads should roll over this screw-up..... |
08-19-2020, 11:14 PM | #19 |
Rep 136
No offense to anybody but I think this feature makes absolutely no sense. If you already have comfort access then all you need is to have your keyfob in your pocket. Otherwise you have to take out your phone every freaking time, unlock it, place it next to the handle. Sounds more cumbersome.
Moreover, what are you going to do if you drain the battery on your phone and don't have a charger/power bank. You're pretty screwed aren't ya? |
08-20-2020, 01:07 AM | #20 |
Rep 243
08-20-2020, 01:10 AM | #21 | |
1197
Rep 1,587
Really useful in that specific scenario. It won't be a game changer until the device can be kept in your pocket like a keyfob. |
08-20-2020, 02:52 AM | #22 | |
Rep 136
