08-12-2020, 11:20 PM | #1 |
Rep 58
Is sound quality worse with Wireless CarPlay? Does CarPlay use Bluetooth or Wifi?
Yes, we all know that sound quality is worse when you are using iDrive Bluetooth when compared to iDrive USB. The mids and highs clip, and the bass isn't as strong. This isn't BMWs fault as there are bandwidth issues with Bluetooth in general. It is well known.
My question pertains to Wireless Carplay. With the new BMWs, wired Carplay is not an option. I am under the impression that the phone communicates with the BMW via Wifi signal, so the audio quality should be perfect (as if it was wired). I just wanted to confirm that is the case? I don't think it uses Bluetooth because there is way too much data (phone, map, apps open, messages, etc.). It makes more sense that it uses WiFi. Please correct me if I am wrong. I have the Bowers and Wilkens Diamond Surround System and I just want to make sure I am getting the best sound. I live in Tennessee and BMW maps are just plain embarrassing over here (constantly takes the long routes and puts me on dead end roads) so I want to switch to using CarPlay exclusively if possible. Plus, Waze is free traffic cam info + mobile cops too It is sad I will lose the HUD directions but I guess its not the end of the world. The main decision maker here will be sound quality. If someone could answer the question, I would appreciate it. Thank you. |
08-14-2020, 09:22 PM | #3 |
Rep 58
08-14-2020, 09:58 PM | #4 |
13236
Rep 19,728
08-15-2020, 05:56 AM | #5 |
Rep 8
CarPlay uses wifi to steam from your phone but is limited to CD quality audio (16bit/44.1kHz); still higher than Bluetooth quality. If you want the best audio quality for your system, you'd need to play music at 24bit/192kHz. That can only be achieved by using a USB to play directly from or to add your music to the car hard drive. Only FLAC and ALAC files support this. Hope that helps.
08-15-2020, 07:35 AM | #6 | |
Rep 58
08-15-2020, 08:40 AM | #7 |
PANIC!
482
Rep 823
If I connect my phone directly to the USB or USB-C port, will that supersede the wireless connection?
I don't believe it does, but I couldn't confirm it when I tested it out myself. I think once your phone is connected to wireless CarPlay then you plug your phone in, it maintains that wireless connection. Can anyone confirm? |
08-15-2020, 09:22 AM | #8 | |
Rep 704
superkrups2005619.50 |
08-16-2020, 05:46 AM | #9 |
Rep 8
HiRes audio files higher than CD quality cannot be played wirelessly in the car. If your phone has those types of files, chances are you're not actually listening to them at that quality as you would need a HiRes DAC to plug into your phone. The same applies in the car (ie using wireless CarPlay or having it wired will give you the same max output at CD quality).
The only ways to get the file playing in your car uncompressed is to: 1. Plug your phone with a HiRes DAC. 2. Play directly via USB plugged into the car. 3. Transfer the files to the car HD since the car can play uncompressed files (FLAC etc). I don't really have one source as this is just from me learning it over time but the most comprehensive source I've found is this: https://www.whathifi.com/us/advice/h...u-need-to-know |
08-16-2020, 11:43 PM | #10 | |
Rep 58
08-17-2020, 01:10 AM | #11 |
Rep 8
Yes, you would need to play through a USB stick.
The lightning connector the phone uses does not play higher than CD quality. So a DAC is required to play any HiRes song from your phone. |
08-17-2020, 01:12 AM | #12 | |
Rep 58
Also, most CD Quality FLACS are 16/44.1 anyways right? So lightning cable should be fine. |
08-17-2020, 01:23 AM | #13 |
Rep 8
For the car, you're better off getting a USB stick (cheaper than DAC) and loading your songs on there. Either play them directly or transfer them to the car (which is what I do) and then you have your HiRes collection always available.
Most DAC only support a 3.5mm output (like a headphone jack) and so you couldn't use those. They're mainly used for listening to music on headphones. Yeah the file type doesn't matter in the case where the quality is only at CD level. The lightning connector or wireless CarPlay will play up to that quality. |
08-20-2020, 09:05 PM | #14 | |
Rep 58
08-20-2020, 09:11 PM | #15 | |
13236
Rep 19,728
CarPlay would not have any effect on playing music from the X5's drive of a USB drive. |
08-27-2020, 12:03 PM | #16 |
Rep 8
I don't see a reason why the size of a hard drive would impact playability via USB. The car's DAC is not related to what hard drive you use to play music. You can use a 1gb hard drive or a 5tb one and theoretically it shouldn't matter.
This has nothing to do with CarPlay which plays music directly from your iPhone wirelessly. |
08-27-2020, 12:14 PM | #17 | |
Rep 58
08-30-2020, 12:45 AM | #20 |
Rep 2,244
08-30-2020, 12:51 AM | #21 | |
Rep 58
I have a bunch of FLACs that I converted to ALAC via DBPoweramp. This should be equivalent to streaming via USB cable (provided the original track is 44/16)? |
08-30-2020, 12:52 AM | #22 | ||
Rep 2,244
This is also how their AirPods work, Alac is used as the transport medium |
