08-21-2020, 07:46 PM | #1 |
Rep 143
X6 tire decision - 20" or 21"?
I'm about to order an X6 non-MSport but with DHP. I actually prefer the looks of the non-MSport even before the consideration of the $3600 more they want to charge for basic trim and a nicer steering wheel.
I'd like some feedback on whether to keep the 20" tires (f&r=275/45) or pay $950 more for the 21" (f=275/40, r=315/35). I do not want 22" wheels at all. Driving is mostly in-town and suburban and only 6000 miles/yr. I did try a vehicle with the DHP and liked the steering and handling a lot more than without, so I've decided that is worth the $3650. What will the realistic benefits, if any, be with the 21's I know I will have a more comfortable and quieter ride with the all-season 20's, and that it will cost a good bit more to replace the performance 21's when they wear out (which they will more quickly). I also realize the 21's will look better, but I want to take that out of this conversation. Many thanks. |
08-21-2020, 08:33 PM | #2 |
13275
Rep 19,802
As I mentioned yesterday, DHP requires you to order the MSport package according to the order guide.
08-21-2020, 09:07 PM | #3 |
Rep 143
I did miss that yesterday. Thanks for the heads up again. So I guess the option is still to go with the 20" M wheels or upgrade to the 21" M wheels. And since I have to spring for the M package as well as DHP package, I would lean towards not paying up for the 21's unless there was a tangible driving benefit.
I guess another way to ask the original question is: I drove an xDrive 40i MSport and DHP with 22 in wheels. Will this same build with 20 in wheels drive any differently in city and suburban driving? If so, what might that difference be and would 21's be noticeably different? Last edited by lair12; 08-21-2020 at 09:46 PM.. |
08-21-2020, 10:04 PM | #4 |
13275
Rep 19,802
I think there were a few conversations going on. The 20" wheels will offer a less harsh ride and probably a quieter one. From the experiences I read, the 21"s will be more like the 22".
08-22-2020, 12:25 AM | #5 | |
35
Rep 49
Thanks. |
08-22-2020, 08:11 AM | #6 |
Rep 143
Part of my confusion camefrom the fact that the on-line Build-Your-Own allows you to spec the DHP without forcing MSport on you. I'm not sure why this is. The DOG does says that you need to have MSport.
08-22-2020, 08:18 AM | #7 |
Rep 143
I was only driving around the BMW dealer in Atlanta (which had SIX X6's in stock, and now claims TEN). I really didn't have the situation where I was on rough or pothole roads and it rained most of the day. But, I admit that I did not feel anything particularly rough in my drive. That made me consider the 21's at least, but I will most likely stick to the stock 20's. I did fast circles in an empty parking lot and felt the car had very little body roll. I also felt the steering was tighter all around, and that is more of what I wanted coming from an X3. It still is a big car for me. Did you know that you can again order the luxury seat "2" package that includes massage ($1600)? That was gone for the list until recently.
Rodrick34.50 |
08-22-2020, 11:42 AM | #9 |
Rep 146
Drives: BMW X5 (F85), 328i (F30)
21's will look better and you will regret it later on if you get the 20's.
08-22-2020, 02:23 PM | #10 |
35
Rep 49
Really dumb noob question, but is the only advantage of 21/22s over 20s aesthetic? What are the tradeoffs/pros and cons of small vs bigger wheels in terms of driving dynamics?
08-22-2020, 02:33 PM | #11 |
123
Rep 333
G06 here and I went with the 21" and it looks very nice imo. I live in NYC and roads here are notoriously bad. I have air suspension and despite the 21", the ride is still quite comfortable on uneven roads and bumps. Floaty, yes, I do feel that sometimes. Stiff suspension and large rims are a bad combo in NYC. I'm not sure where you live, so.....
08-22-2020, 02:52 PM | #12 |
35
Rep 49
I don’t want to hijack the thread, but it’s the same subject matter. I’m in Montreal. Roads will be as bad or worse than NYC. I test drove the X6 with your set up (air with 21” rft) and had the exact same impression as you. Very comfortable ride, with somewhat of a ‘floaty’ feel (not bad, just depends what feel one prefers). I ordered my car with adaptive M with DHP (same as OP). Initially ordered with the 21” as a middle ground. Dealer is recommending going with 22” (I’ll get a separate set of 20s for winter), but I’m actually now thinking of just ordering with the 20” (740M) and if I like it I’d just swap between winters and summers/AS on the 20” rims. I don’t mind the look of the 740M rims (actually quite like them), but I guess like the OP I’m wondering if the 20” give up (or gain) anything tangible in driving dynamics compared to the bigger wheels. Are the bigger wheels ‘just’ for aesthetics (which is generally the sense I get from this forum) or are there practical benefits as well. Sorry for the noob queries.
08-22-2020, 02:55 PM | #13 |
Rep 479
You could change out the run flat for non run flats on the 21s and get better ride quality. It will
Still be noisier than the 20s. I just downsized my wheels from 21 to 20. Big difference in tire noise and ride comfort. The car rolls a bit better with less resistance so I expect fuel economy will improve a bit too. I went with the Bridgestone Alenzas RFT but wish I had gone with non run flats to maximize ride comfort. The Bridgestones are good for a RFT tire but is still not as a good as a non RFT tire. I have air suspension on an m Sport. |
Rodrick34.50 |
08-22-2020, 03:04 PM | #14 |
Rep 3,074
Drives: G06/G20/F30/F15/F10/E90
I would go against the flow on this one and say go with the 20" Why? Many reasons (1) Less harsh ride (2) Better Comfort (3) Less noisy (4) Better mpg Also, if I get this car as a commuter, I want it to have AS tires, so no bother changing every season (lazy dude here ). One more thing Air suspension is a big no for the X6, makes the car drive like a boat in a windy day 🛶
08-22-2020, 03:49 PM | #15 | |
Techie
16
Rep 105
08-22-2020, 08:44 PM | #16 |
Rep 143
Bigger wheels to not mean bigger tire circumference at all.
Check out here for all the exact details on tire size vs wheel size. https://tiresize.com/calculator/ |
08-22-2020, 08:46 PM | #17 |
Rep 143
The 21" will give you only 1/2" of extra visual radius which is then lost in sidewall height. I'll also end up with staggered tire sizes, and much higher tire costs (with more frequent replacements).
08-22-2020, 08:49 PM | #18 | |
Rep 143
I'm in Raleigh, and will be getting the DHP, for better steering and handling and do not want the floaty feeling that I otherwise am trying to avoid. So mostly highways and suburban roads.
08-22-2020, 08:52 PM | #19 | |
Rep 143
I looked into this and found very little choice for anything other than expensive performance tires for the 275/40 and 315/35 setup on the 21's if you were to get matching models. That gave me some real pause.
08-22-2020, 08:59 PM | #20 | |
13275
Rep 19,802
Front: Rear: Last edited by TurtleBoy; 08-22-2020 at 09:03 PM.. Reason: Corrected calculation |
08-22-2020, 09:00 PM | #21 | |
Rep 143
I'm very much leaning this way, although as a special order I would probably have time in the next 10 weeks to change. In theory, part of the M-Sport package $4500 should be allocated for the M-Sport wheels, but as you all know, you get no credit for this if you upgrade to 21 or 22. So in the end I have to pay $3600 (after premium package credit) more for a steering wheel which costs BMW no extra money and some painted trim which costs them nothing much more either! And to get the DHP I have to order the MSport. That $3600 must flow right to their profit line.
08-22-2020, 09:09 PM | #22 | |
13275
Rep 19,802
