01-01-2021, 07:00 PM | #45 | |
Rep 127
01-01-2021, 11:33 PM | #47 |
Rep 127
01-01-2021, 11:57 PM | #48 | |
Rep 6,875
The vehicle will drop the max rate it pulls based on how full the batteries are, and how hot they are, but that is a different action than setting the maximum charging rate. Otherwise, if the EVSE announces it has a certain amount, the vehicle will never try to pull more than that, so the 10A one BMW supplies, even if the menu is set to 16A, still won't try to use more than what the EVSE says it can supply. Even if it was capable of sending 50A to the vehicle, our X5 45e in its current state won't try to pull more than 16A, but could reduce that if the menu was set lower. In the USA, using the level 1 device supplied, or any other level 1 device you might buy, is less efficient than using a level 2 device, as the onboard charging power supply is less efficient making the high DC volts required to charge the batteries using 120vac versus 240vac. It would probably save you $0.10-0.20 per charge cycle, depending on what your local power rates are. Mine are about $0.20/Kw. level 1 charging is in the order of 6-10% less efficient than level 2. |
01-02-2021, 12:02 AM | #49 | ||
Rep 2,420
I had the 11/2020 update that should have taken care of the problem. It didn't see it since the update was done. Might be to soon. Or maybe they did take care of it. |
01-02-2021, 03:18 AM | #50 |
Rep 804
01-02-2021, 06:34 AM | #51 | |
Rep 127
01-02-2021, 07:01 PM | #53 |
Rep 127
Then one issue I have had is that I had a full discharge from driving. When I plugged in, it stopped charging around 94%. I had to disconnect and reconnect the charger to get the last 6%
01-02-2021, 08:06 PM | #54 |
Rep 8,775
Drives: eVeRyOnE mAD!
interesting, after my first full discharge, it stopped charging @ 84%. disconnected then reconnected to finish the charge, too.
01-02-2021, 09:39 PM | #55 |
Rep 127
01-08-2021, 07:42 AM | #56 |
Rep 3
I took delivery of my Vehicle in December. Most of the time, it charges at 15A but after a few times, it goes to 6A for no good reason. I can change it back to 16A while it's charging and it'll change to 15A right away. Is this a software glitch or a hardware issue?
01-08-2021, 02:14 PM | #57 | |
Rep 6,875
The X5's maximum charge rate is 16A. The EVSE sends a pilot signal out that tells the vehicle how much current it is allowed to draw. Unless the software in the vehicle is restricting it, it will pull the maximum allowed. Exactly why the vehicle sometimes drops the maximum charging rate down, I'm not sure anyone has figured that out and apparently, not even BMW, as it has been in several software builds. Not sure if the latest one for November 2020 fixed it or not...I'm on the July update. |
01-09-2021, 10:26 AM | #58 |
45
Rep 340
Just got ours. No issues yet with the rate changing but omg 16A is SO slow. Hopefully they unlock it to normal Level2 charge rates in future.
NASA GTS3 Race Videos: https://www.youtube.com/user/magnetic1
Hoosier R7/A7 2753518 Scrubs w/ 8-12HC always for sale ~$100ea (PM) Individual Avus F80; Individual Avus E46 M3; Tanzanite Blue E46 M3 Racecar! |
01-09-2021, 05:53 PM | #62 | |
Rep 6,875
The supplied device is 10A, and in the USA , is designed to plug into any 15 or 20A receptacle. They chose 10A to help prevent the common circuit breaker in a garage from tripping should you decide to close your garage door and the motor overloaded the circuit. The largest it could use on a 15A circuit is limited by the electrical code to 80% of the max, or 12A (16A on a 20A circuit). Most any level 2 EVSE should be able to charge the vehicle overnight easily. A level one, probably not. If you don't ensure the X5 menu is set to 16A, it doesn't matter, it won't pull maximum current and therefore, limit the power going into the batteries. The only reason to drop the menu level is if the EVSE has to share its power with something else, and you need to prevent it from overloading the external circuit. |
01-09-2021, 10:48 PM | #63 | ||
45
Rep 340
Not sure why BMW decided this was the rate they wanted. It isn't like battery tech can't handle it.
01-10-2021, 12:20 AM | #64 | |
Rep 6,875
They certainly do have vehicles with faster charging rates, but they're all BEVs. The i3, for example, uses essentially two of those modules. Not sure about their x3 BEV, as they chose not to sell it here, and it'll be another year or so before their next i-car will show up. |
volodp199.50 |
01-10-2021, 12:27 AM | #65 | |
Rep 3
I checked my car and it says: 07/2020.54 That's very surprising considering that I got the vehicle delivered in December 2020. When I tried to do a software update, it tells me that no new one is available. Should I take this in to the service centre to have them update it? Thank you again for the help! |
01-10-2021, 12:35 AM | #66 | |
Rep 6,875
New firmware fixes bugs, adds enhancements, and probably other things as well. It seems nobody but BMW knows when they update any specific vehicle. If you have an issue, and you're at the dealership, they may update the vehicle while it's in for service, but generally, unless there's something that isn't working right for you, there's no reason to just go in to update it. I have the laser headlight option, and am hoping that BMW chooses to update them to their fullest capabilities sometime down the road. If it doesn't happen in say the next six months or so, I may pay someone to do that for me, as BMW won't until it's officially legal and released for the USA, if ever, for older vehicles. |
