F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > How to know if my vehicle has RDC TMPS receiver?
GetBMWParts
      09-09-2020, 10:50 PM   #1
EclipseK
Drives: BMW-F34
Hi everyone,
I’m going to upgrade my TMPS into RDC TMPS, which could show temp and the psi instead of showing my tire pressure is good.
But I just wonder if my vehicle has the receiver of this type of sensor. Does someone know how to check if my vehicle has it or not?
BTW, I’m in Canada, and this vehicle seems to be made in Germany, and it is 2016 335i GT XDrive.
Thank you guys.
      09-10-2020, 07:25 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
If you don't have RDC then you'd probably need to add an RDC receiver module as well as sensors, and you'd probably have to do VO coding to get it to work.
      09-10-2020, 08:13 PM   #3
EclipseK
Drives: BMW-F34
Thank you for replying.
I understand I need to code it, but just wonder if it has the receiver. Someone told me it has...
And does your vehicle have the temp and psi reading?
      09-10-2020, 09:26 PM   #4
Billfitz
Billfitz's Avatar
Mine has the PSI, and I assume the temp as well, but I've never bothered to code it to active. I can see that feature as useful on the track, but otherwise not so much. You can use https://www.newtis.info/tisv2/a/en/f...t/search?q=rdc to find the RDC receiver location and see if you have one. I doubt it, it wouldn't seem likely BMW would put one on a car that doesn't have the RDC system.
      09-11-2020, 07:01 AM   #5
EclipseK
Drives: BMW-F34
Thanks a lot.
It seems so complex to do. But thank you anyway.
      09-11-2020, 07:31 PM   #6
Torquey
Drives: 335i GT | 550i 6MT
It's very easy to find out/ code if you have the Bimmercode app (~$30 from Google Playstore) and an OBDII Bluetooth adapter like VeePeak (another $30 or so from Amazon). It will also offer you a whole host of other coding options. Definitely a recommended investment!
      09-11-2020, 08:37 PM   #7
EclipseK
Drives: BMW-F34
I have both. But how can I know the answer by this two parts? Which section in BimmerCode should I go after?
Thanks
      09-11-2020, 08:53 PM   #8
Torquey
Thanks
If you can do this then your car i believe must have it...
      09-11-2020, 10:05 PM   #9
Billfitz
Billfitz's Avatar
The OP does not have TPMS with that readout on iDrive. It's standard in the US, but not in Canada. He's asking if he can retrofit it. He can't code what he doesn't have.
      09-12-2020, 01:52 AM   #10
3-GT
Wales
333
Drives: BMW 320d GT
Some info here you may find useful.
https://f30.bimmerpost.com/forums/sh...d.php?t=941641
f30post
