09-19-2020, 08:36 PM | #1 |
Rep 172
Wheel speed sensor
Hi,
I have the chassis stabilization , abs, cel warning lights, which is typical of my wheel speed sensor. Bought the following part number 34526884423, and after changing the sensors, - the error didn’t go away. In fact, I got the airbag malfunction error as well now - the steering became heavy (Was normal before I replace) - Automatic trunk does not work (can still open by force) - retractable spoiler deployed and couldn’t get it down I bought my own parts and the workshop installed for me. They suspect I got the wrong part. Has anyone faced similar experience, and managed to get it resolved? What would be the next troubleshoot to do? Thanks! |
09-19-2020, 09:07 PM | #2 |
8243
Rep 16,082
The error won't go away because you changed the sensor. You have to clear it with an OBD diagnostic and repair tool. You might not have had to replace it. I got the entire set of warnings associated with ABS sensor failure. I used my Foxwell NT510 to diagnose the problem, clear the codes, and then function test the sensors. They were all fine. Two years later the problem never returned.
angelforce7.50 |
12-10-2023, 10:11 AM | #6 |
Rep 1
Hey buddy! I am hoping you are still on these forums
But i having the literally exact issue you did with swapping wheel sensor And the steering wheel getting heavy with air bag light and i cannot find A single thing online about it and was wondering how you got it fixed? THANK YOU IN ADVANCE! |
