09-21-2020, 08:57 PM | #1 |
BimmerPost Supporting Vendor
24199
Rep 190,807
ARM Motorsports F Chassis Intercooler - Top Quality || Unbeatable Price !!
www.extremepowerhouse.com
Why shop with us? Lowest Price Guarantee: We do our best to always have the lowest price on our website, but if you found an even lower price somewhere else let us know. We will match the other price and thrown in an extra $25 store credit towards your next purchase. Financing: We offer 6 months no interest financing. Get the products now, pay later. You can at anytime pay the full amount or make partial payments during these 6 months. If after 6 months, you still have balance remaining on your account there will be a minimum monthly payment with interest applied, subject to credit approval. Customer Service: We offer the best customer service, period! Don’t take our word for it, check out what our customers have to say about Extreme Power House https://www.x-ph.com/customer-reviews/ Hours: We open 7 days a week from 8 AM to 11 PM Pacific Time. Contact us: For any questions you can pm / email Mike@x-ph.com or call 702 494 9435. If you contact us during business hours, expect a reply within the hour. If you contact us outside of the regular business hours, expect a reply within 6 hours. Chat: Looking for an immediate response to your questions? Go to our website www.x-ph.com and use our chat functionality. Payments: You can make a purchase directly on our website www.x-ph.com or give us a call at 702-494-9435 and we can process your order over the phone. Shipping: Expect to get a tracking number from us same day of your order completion. We try our best to get the products delivered to you ASAP. We ship items using USPS, UPS and FedEx. Contact Mike@x-ph.com for expedited shipping options. Inventory: We stock all the popular products at our Las Vegas warehouse. If item is not in stock, we will get it drop shipped to you directly from the manufacturer’s location. XPH Rewards: We now offer Extreme Power House loyalty points to all our loyal customers. Earn 1 point after every $1 you spend with us. Earn more by sharing our website on social media and referring your friends. Newsletter: Join our newsletter for the latest XPH news, exclusive deals, group buys and coupon codes. We also offer exclusive newsletter flash sales. Order Link https://store-gd6olw6.mybigcommerce.com/arm-motorsports-f-series-m235i-335i-435i-m2-intercooler-fmic/ HIGHLIGHTS • Increase HP / TQ • 120% Larger Front Area • 94% More Efficient than OEM • Fully Reversible PROFILE An ARM F30 Intercooler upgrade is one of the best modifications you can make to your 335i. One of the F30 335i's most significant weak-points is its stock intercooler. This becomes obvious when tuning the N55 to increase boost with a Stage 1 tune and even more so with a Stage 2+ tune. With a higher boost target the charged air coming out of the compressor is hotter, therefore increasing IAT's. To compensate for the higher IAT's the ECU (DME) reduces boost, timing, and overall power to the engine. This is the exact opposite of what you want for getting your F30 335i to run faster. In order to keep those IAT's low, a larger and more effective intercooler is needed. CONSTRUCTION The ARM F30 335i FMIC is the perfect cooling solution for any stock turbo or upgraded turbo N55 setup. With an intercooler core size of 20x11x3" and an overall volume of 660cu in. the ARM F30 FMIC is 235cu.in. or 36% larger than the stock N55 intercooler which comes in at only 425cu in. In addition, the ARM F30 FMIC utilizes an ultra-dense 14 fins per inch external core, giving it the best cooling performance possible. F30 Intercooler FMIC ARM Motorsports 335i With a 220sq.in. face the ARM F30 335i FMIC has a 120% larger frontal area than the OEM intercooler with only a 100sq.in face, and 120sq.in. larger than oem and 55sq.in./33% larger than most aftermarket F30 intercoolers. Having a larger frontal area equates to more effective cooling compared to intercoolers of similar total volume. In the milliseconds that the ambient air passes through the intercooler it warms up, making the actual cooling less effective towards the rear of the intercooler. Taking the area towards the rear of the intercooler and bringing it towards the front improves the overall ability of the FMIC to cool the charged air on the N55. This is shown in our IAT testing results below. F30 335i 328i Intercooler FMIC upgrade N55 N20 ARM Motorsports INTAKE AIR TEMPERATURE RESULTS Our baseline run was performed on a 335i running 16psi of boost with the stock F30 intercooler. The 3rd gear run started at 93 degrees and ended at 126 degrees, a huge increase of 33 degrees Fahrenheit on 16psi of boost, and certainly restricting the amount of power this N55 could have been making. After installing the ARM F30 FMIC there was a massive improvement in cooling performance that resulted in only a 2 degrees Fahrenheit increase in IAT. In this 3rd gear run with boost peaking at 18psi, which is 2psi higher than the stock intercooler run, it starting at 95 degrees and ended at only 97 degrees. This is a 94% improvement in cooling over the OEM F30 intercooler! INSTALLATION Installation of the ARM F30 335i FMIC upgrade requires no cutting, trimming or removal of the front bumper or radiator shroud. It is a direct fit which bolts up into the original stock intercooler location. The CNC connectors will connect to either the stock F30 intercooler piping or to any upgraded intercooler piping that fits the stock intercooler. F30 HOSE UPGRADE If you're looking to improve the charged airflow and simplify your intercooler piping, the ARM Motorsports F30 FMIC Hose Upgrade is available as an optional upgrade. This hose upgrade is designed to fit the ARM F30 Charge Pipe upgrade and eliminates the need for the stock F30 intercooler connections altogether. It reduces the total amount of connections by 50%, from 4 to 2 on the driver side, and 4 to 3 on the passenger side. The ARM F30 Charge Pipe is required to fit the ARM F30 FMIC Hose Upgrade. IN THE BOX • ARM F30 FMIC • OEM Style Connectors • Mounting Hardware • Hoses and Clamps FITMENT GUIDE Make` Chassis Model Engine BMW F22 228i N20/N26 2.0L BMW F22 228i xDrive N20/N26 2.0L BMW F22 M235i N55 3.0L BMW F22 M235i xDrive N55 3.0L BMW F23 228i N20/N26 2.0L BMW F23 228i xDrive N20/N26 2.0L BMW F23 M235i N55 3.0L BMW F23 M235i xDrive N55 3.0L BMW F30 320i N20/N26 2.0L BMW F30 320i xDrive N20/N26 2.0L BMW F30 328i N20/N26 2.0L BMW F30 328i xDrive N20/N26 2.0L BMW F30 335i N55 3.0L BMW F30 335i xDrive N55 3.0L BMW F31 328i xDrive N20/N26 2.0L BMW F32 428i N20/N26 2.0L BMW F32 428i xDrive N20/N26 2.0L BMW F32 435i N55 3.0L BMW F32 435i xDrive N55 3.0L BMW F34 328i xDrive N20/N26 2.0L BMW F34 335i xDrive N55 3.0L BMW F36 428i N20/N26 2.0L BMW F36 428i xDrive N20/N26 2.0L BMW F36 435i N55 3.0L BMW F36 435i xDrive N55 3.0L BMW F87 M2 N55 3.0L
10-16-2020, 12:02 PM | #2 |
24199
Rep 190,807
12-02-2020, 03:17 PM | #3 |
24199
Rep 190,807
12-20-2020, 01:39 PM | #4 |
24199
Rep 190,807
01-11-2021, 05:52 PM | #5 |
24199
Rep 190,807
02-02-2021, 11:36 AM | #6 |
24199
Rep 190,807
02-24-2021, 03:20 PM | #7 |
24199
Rep 190,807
03-18-2021, 05:42 PM | #8 |
24199
Rep 190,807
04-08-2021, 05:29 PM | #9 |
24199
Rep 190,807
04-29-2021, 05:41 PM | #10 |
24199
Rep 190,807
05-25-2021, 11:59 AM | #11 |
24199
Rep 190,807
06-17-2021, 05:54 PM | #12 |
24199
Rep 190,807
07-10-2021, 11:34 AM | #13 |
24199
Rep 190,807
08-04-2021, 11:39 AM | #14 |
24199
Rep 190,807
08-28-2021, 11:32 AM | #15 |
24199
Rep 190,807
09-22-2021, 11:34 AM | #16 |
24199
Rep 190,807
10-14-2021, 05:25 PM | #17 |
24199
Rep 190,807
11-09-2021, 05:25 PM | #18 |
24199
Rep 190,807
12-14-2021, 02:56 PM | #19 |
24199
Rep 190,807
01-14-2022, 02:30 PM | #20 |
24199
Rep 190,807
08-08-2022, 02:07 PM | #21 |
24199
Rep 190,807
09-19-2022, 09:40 AM | #22 |
24199
Rep 190,807
