02-12-2021, 11:08 PM | #1 |
Rep 121
How to get rid of the door squeak/creeck noise
I have been wanting to share my experience on finding a semi permanent solution for the never ending door squeaks, specially on low speed driving. It drove me crazy to the point that I wanted to return the vehicle, and be done with it. Luckily, after some investigations and door pushing!, found out that the upper sealant on the inside part of the door is the cause of this unpleasant noise. Had some clear paint protective film that I used on the door sills, used it and surprisingly solved the problem. I taped all over the inside of all the doors, where the upper door sill touched the frame/body of the door. Right now, all my doors are creek free.
02-13-2021, 10:23 AM | #3 |
Rep 121
I bought the tape on Ebay. Just go ahead and type "Car Door Edge Paint Anti Scratch Strip Clear Protective Guard Film" on Ebay, and you would see many options. As you could see on the last picture, I bought many different sizes, but IMHO the best size to purchase would be 3CM X 3Meters.
06-28-2021, 08:39 AM | #5 |
Rep 530
Drives: 2020 BMW X5 MSport Arctic Grey
Same here...bought the tape. 10 min install...been quiet ever since. Cheapest fix I have ever done.
2020 BMW X5 M-Sport
2021 Audi Q7 Prestige 2016 Aston Martin Vantage V8 |
volodp196.50 |
06-28-2021, 06:29 PM | #8 |
Rep 121
The first picture does not show where you apply the clear tape. That picture shows the top of inner edge of your car doors, it is what is making the noise. The other picture show where you should apply the tape. Let me know if you have any other question.
Frenetic482.00 |
06-28-2021, 06:50 PM | #9 |
Rep 901
Drives: 2018 M3 Competition
Good to know. We had the same issue on both sides. My wife took it to the dealer and she said they applied silicone to lubricate the seals. It's been a few weeks and so far, so good.
I will go with this solution if it ever comes back. |
06-28-2021, 07:32 PM | #10 |
Rep 254
I put Gummi Pflege on that seal and noise is gone. Every BMW I've ever owned needs that stuff.
rogerramjetx59.00 BzsBimmer3274.00 |
06-28-2021, 11:16 PM | #11 |
Rep 668
I used Gummiplege on the doors as well. Now the only rattle I have is from the sunroof, and I think I need to take it in for that. Also something in my door panel buzzes at certain frequencies when listening to talk radio.
Really wish BMW would better design to eliminate buzzes and rattles like Audi does. My old Audi never rattled over the 6 years I had it. |
gofast182628.50 rogerramjetx59.00 |
06-29-2021, 07:14 AM | #12 | |
Rep 530
I am having the nastiest rattle in the sunroof....it came on quick and big.
Dealer Thursday for it. Quote:
2020 BMW X5 M-Sport
06-29-2021, 07:27 AM | #13 | |
Rep 4,333
After several cleaning attempts, the noise is 80% gone but the 20% still bugs me. I hesitate putting Gummipflege or anything else on it as it did not come that way from the factory and it didn't squeak till I detailed it. Sorry, I don't have pix at this writing but here is a copy of the one already posted that I annotated to try and get some clarity as to where you are putting the Gummipflege. . |
06-29-2021, 10:44 AM | #14 | |
Rep 121
06-29-2021, 11:47 AM | #16 |
Rep 530
Ordered GummiPflege originally - but it did not work at all. The tape is a more permanent solution.
2020 BMW X5 M-Sport
06-29-2021, 12:17 PM | #17 |
Rep 3
Hey BMW community. Im new to the BMW world and these forums. I have a G05 40i that had a terrible rattle coming from both rear doors. I tried a million things to correct it.... and nothing worked.... until.....
After reading the above post i decided to thoroughly wipe down / clear both the door seals on both sides (door seal + body seal) as a long shot. It worked! My rattles seemed to be due to really dirty / dusty door seals that were moving rubbing against the body while driving over rough terrain. If you guys are having similar issues, i highly recommend trying this! |
06-29-2021, 03:16 PM | #18 | |
Rep 4,333
06-30-2021, 03:49 PM | #19 |
Rep 289
this has been around since E60….. it was a known issue solved under warranty by the dealer - same fix - just clear tape )
sad to see it came back 15yrs later 🤦🏻*♂️ |
07-01-2021, 04:55 PM | #20 |
Rep 6,805
There is a BMW door gasket dressing that is likely to help. Supposedly, it not only helps them to slide without noise, but prolongs their life. It's not cheap. There's another one out there, but it's been awhile since I looked and don't remember its name, but it's something like bonseal.
07-01-2021, 05:14 PM | #21 |
Rep 2,632
07-02-2021, 11:36 PM | #22 |
519
Rep 1,730
This was an issue for my f80 m3. The tape is the only permanent solution.
2018 Grigio Telesto F80 M3 DCT | :: Bone Stock :: 2004 Titanium Silver E46 M3 6 Speed | :: Track Car :: |
