03-12-2021, 02:48 PM | #1 |
Rep 87
Can 1 X5 have 2 Driver Profiles Using Connected App?
I have the Connected App on my iPhone, and I have my Driver Profile set up. My Driver Profile is also connected to my key (Key 2). Everything works flawlessly.
If my wife (who's actually the main driver), downloads the Connected App to her iPhone, can she setup her own Driver Profile on it, and connect her key (Key 1) to it?
2020 BMW X5
2023 Porsche Carrera T 2022 Ford Bronco 2DR Wildtrak |
03-12-2021, 03:55 PM | #2 |
Rep 8,818
Drives: eVeRyOnE mAD!
yes. she then needs to log into your car with her Connected credentials in order to complete the driver profile setup
03-12-2021, 04:10 PM | #3 |
Rep 4,246
If your wife is the primary driver and primary subscriber to BMW ConnectedDrive, she can add you as a secondary subscriber to the account. This allows you to set up a ConnectedDrive account and your associated driver profile to cloud back up your profile and settings. You can download the app and sign in using your credentials.
03-12-2021, 04:11 PM | #4 | |
20
Rep 44
03-12-2021, 04:18 PM | #5 | ||
Rep 4,246
03-12-2021, 04:23 PM | #6 | |||
20
Rep 44
Or do I just register for new connecteddrive accounts once the cars come in? |
03-12-2021, 07:41 PM | #7 | |
Rep 87
2020 BMW X5
03-12-2021, 08:28 PM | #8 |
Rep 87
^^Never mind. I figured it out, added my wife as a Secondary Subscriber, and created her driver profile, linked to her key.
2020 BMW X5
03-13-2021, 10:13 AM | #9 | ||||
Rep 4,246
When your vehicles arrive, you'll complete an ESA (electronic subscriber agreement) for BMW Assist and ConnectedDrive. BMWUSA and ConnectedDrive accounts are not one in the same. You can use the "joint" email address associated with the BMWUSA account or you can use your email (different than BMWUSA) for BMW Assist and ConnectedDrive ESA for both vehicles and can update your BMWUSA and BMWFS email addresses for sanity and consistency - this would be my recommendation. The ESA will have a primary and optional secondary subscriber info. For one vehicle, you can use your info for primary and wife secondary and for the other vehicle, your wife primary and you secondary. Or you can keep it some and use your info for primary and wife secondary for both vehicles. In either case, confirm make sure the secondary subscriber is activated. The email addresses you provide will be the email address you'll use to setup and access your ConnectedDrive account on the website and iOS/Android mobile app. In the ConnectedDrive app, you can add one or both vehicles using your VIN and switch as needed. I use identical email addresses for BMWUSA and BMW ConnectedDrive but of course different passwords. My X5 xDrive40i and M550i, are registered under one BMW ConnectedDrive and Assist account. I have a secondary subscriber account enabled for my associate. Is it possible for two people, who both use the same vehicle, to each have separate access to the BMW Connected app on their own devices? Yes, multiple devices can be used to log into the same vehicle. When using the same ConnectedDrive account (i.e., username and password), the destinations shown in BMW Connected will be the same across all of the devices. If using different ConnectedDrive accounts (i.e., each person logs in with a separate username and password), the destinations will be personalized to each account. FAQ_BMW_Connected.pdf BMW ConnectedDrive FAQs
Superman75020.00 |
03-29-2021, 09:45 PM | #11 |
Rep 156
03-29-2021, 11:34 PM | #12 | |
Rep 4,246
Grumpy31137.50 |
03-30-2021, 08:18 AM | #13 | ||
Rep 156
