F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > fluid leak by front left wheel
proTUNING Freaks
      03-12-2021, 11:07 PM   #1
washufiddyfo
Drives: 2018 340GT x-Drive
I have a very slow oil-like drip coming from the control arm by my left front tire. Can anyone help identify a possible source or point me in the right direction?
I have read a lot about the infamous OFHG and this does not seem to be that, as I can't see oil anywhere down the front of the block by the belt, or on the side. For that matter, when looking from the top with the engine cover off, I can't see oil anywhere.
It's just this one spot down underneath, and looking around there, I can see splatter off to the side but it doesn't appear to be dripping down from anywhere.
Any ideas? Thanks in advance.
      03-13-2021, 03:54 AM   #2
3-GT
Wales
333
Drives: BMW 320d GT
That's looks like a hydro bearing. They're filled with fluid, it's most likely perished and leaked.
The bearing is replaceable on its own but I believe most just replace the complete arm.
      03-13-2021, 07:45 AM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The bearing, #10 in the link, is about $100 less expensive than the control arm, #9 in the link.
https://www.realoem.com/bmw/enUS/sho...diagId=31_0993
I'd only replace the control arm if it seems that the ball joint is worn.
      03-13-2021, 10:12 AM   #4
washufiddyfo
Thanks, this place is the best. I thought it had to be coming from inside that spot but know those were lubricated that way. Sounds like my swap back to summers is going to take a little longer than usual this time around.
      03-13-2021, 06:19 PM   #5
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i, ‘18 m550i
As long as you have a press and the right dies, this makes sense. Paying a tech to press out the old bushing and press in the new one is not a good value proposition.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
      03-15-2021, 08:45 AM   #6
R BMW
R BMW's Avatar
Drives: 2014 328Xi GT, 2020 X3 MC
2020 BMW X3 M Comp  [0.00]
2014 328Xi GT  [10.00]
Dont forget to have it aligned after.
      03-15-2021, 09:12 AM   #7
johnung
Drives: 2015 BMW 335i x-Drive Auto
Definitely sounds like fluid leaking from your front Upper Control Arm bearing.
You didn't say which model you have but diagram appears like F3x RWD.
Rather than just fix the stock issue, you have an opportunity to dramatically improve your steering by installing these replacement Upper Control Arms with monoball bearings. They get rid of one of the biggest complaints of the F3x, the vague steering. This is easily in my Top5 mods for any F3x.
Below is the link to RWD version. There is also an xDrive version.
https://www.kiesmotorsports.com/prod...8;_ss=r?aff=22
      03-17-2021, 01:52 PM   #8
washufiddyfo
I have the X-drive; I just found that image to more easily identify the part from the first pictures as it gets tough to orient yourself with a close-up like that.
I have spent a fair amount of time on the Kies youtube channel but hadn't seen those yet, will have to check them out. And I found the other thread where you were talking about these, figured I might link it here in case anyone sees this down the road and wants to check them out in more detail.
      04-28-2021, 10:35 AM   #9
washufiddyfo
Well I did it, went ahead with changing both the the VAC monoball so hopefully I never have to worry about it again and improve the driving dymanics at the same time.
Install was great with the video @3-GT shared, not overly difficult assuming the right tools were available. It drove fine to get aligned the next day, and I definitely concur with prior reviews on the tradeoff, feel the road a bit more and the steering has tightened up.
KCee41.00
f30post
