03-17-2021, 02:38 PM | #1 |
Steve K
Rep 55
Power from rear view mirror for radar detector
Has anyone powered their radar detector from the rear view mirror and if so how difficult to make the connection?
04-03-2021, 11:09 PM | #2 | |
Rep 55
Drives: BMW Z4 M40i
BLend Mount
I send pictures tomorrow. https://blendmount.com/ |
04-04-2021, 06:41 AM | #3 | |
Steve K
Rep 55
Thanks again. Steve |
04-05-2021, 02:17 PM | #4 |
Rep 55
Drives: BMW Z4 M40i
Some people are taking off the mirror for easier access. I was able to get the connector removed but it was still difficult to press the power tap .
I used this as a starting point. https://g20.bimmerpost.com/forums/sh...ght=mirror+tap |
05-14-2023, 10:13 AM | #6 |
Rep 1,144
Drives: Z4 M40
Garage List 2015 Yamaha FZ-09 [10.00]
2018 BMW S1000XR [9.83] 2018 BMW R1200RT [10.00] 2023 BMW X4 [7.88] 2022 BMW Z4 [9.78] |
Old thread, but....
I just did the mirror tap in my 22 g29. The couple of threads on this are pretty helpful, but the one misleading point i found is the discussion about either removing the plug or the mirror to insert the taps. After a little struggle i figured out that you don't need to do either. Just use the smallest tap ends and insert them in the far right (red) and far left (blk/brown) wire slots on the larger plug using needle nose pliers. Takes a little bit of pressure but far less than removing the mirror or extracting the plug. If i were to do it again, it's 5 min tops from start to finish.
2022 Z4 M40 Alpine White/Magma Red
2023 X4 30i MSport BSM/Cognac 2018 BMW S1000XR & BMW R1200RT 2015 Yamaha FZ-09 |
05-14-2023, 06:56 PM | #7 | |
Rep 785
Drives: 2021 Z4 M40i
05-14-2023, 07:31 PM | #8 | |
Rep 1,144
Drives: Z4 M40
Just remove the plastic around the mirror base, tilt the mirror down and push the red tap into the back of the larger of the two plugs in the red wire hole and do the same for the black wire tap into the brown/black wire hole in the same plug. Hold each tap with needle nose pliers and insert them into the plug by following the car's existing red and brown/black wires into the back of the plug. Wrap the excess power cord around the mirror base to expose only what you need and reinstall the plastic around the mirror. Do a wire tap search for the thread and instead of removing the mirror or the disconnecting the plug, all I'm adding is to insert the taps with needle nose pliers with the plug in place. Just make sure the car is off when you do this.
07-07-2023, 09:12 AM | #9 | |
Rep 4,493
Drives: 2022 Z4 M40i, 2021 228i GC
Also, does the Blend Mount bracket allow you to remove the detector when parked on the street so some idiot isn't tempted to slash the ragtop and steal it? |
07-07-2023, 12:16 PM | #10 |
Rep 1,144
Drives: Z4 M40
WG,
I actually bought the Uniden R4. From all the reading I did, it has one of the best ranges available. I really only need a RD for mountain driving and I've read that long range is key in that setting. I bought mirror taps from amazon (https://www.amazon.com/dp/B082V1245P...oduct_details) and this stick-on mount (https://www.ebay.com/itm/115353726032) and I keep the RD in my arm rest when not in use. The RD is very easily removed from the glass mount and when the mount is not in use, it's small and out of your line of site unless you are looking up through the windshield. The pics in this thread are not of my implementation. I went more stealth with mine (see below). I went with the R4 also because it's fairly small and the arrows of the R8 or V1 don't matter to me and result in a larger device. It really was very easy, just follow my comments above about the needle nose pliers and which wires to tap and you'll be surprised how easy it is. Hardest part is just trying not to break any tabs on the mirror surround, but if you find a parts schematic of the mirror surround, you can pretty easily avoid that.
2023 X4 30i MSport BSM/Cognac 2018 BMW S1000XR & BMW R1200RT 2015 Yamaha FZ-09 Last edited by SpeedyATL; 07-07-2023 at 12:35 PM.. |
07-07-2023, 01:23 PM | #11 | |
Rep 4,493
When I lived in NYC and drove out of the city either north on the NYS Thruway or east to the Hamptons I used my V1 all of the time as the highways were loaded with police using radar and laser. The V1 saved my butt countless times as I was always over the speed limit. However since I moved to Florida I have discovered that the drivers here are crazy and unless it is rush hour the average speeds can be 80+ and I rarely see a police car on the highways. I haven't seen the need to use my old V1 yet even though it is still effective but we are planning some out of state road trips and where I may need a new RD with today's advanced technology. I am sure it is great for the various types of radar but how good is the R4 for laser detection as the V1 Gen2 is supposed to have the greatest sensitivity to police lasers? Also is it good at filtering out false alerts? |
SpeedyATL1905.00 |
07-07-2023, 01:52 PM | #12 |
Rep 1,144
Drives: Z4 M40
There are NO good detectors for laser guns. All a RD does for laser is notify you that you just got a ticket. Once he shoots you, it's over and apparently a laser detector doesn't detect when he shoots other cars.
Atlanta (where I live) is the mecca of Laser guns. One of the major brands is made here so we see them all the time. The only thing that will help with laser is a jammer - ALP seems to be the best brand. I got estimates for jammers on my Beemer (S1000Xr) and it was going to be close to $2k. But then I realized that I only really worry about tickets on rural/back roads where I ride and regular radar is FAR more typical there than laser. So I passed on the install. Check out Vortex Radar on YT. He has some really great videos on both RD and Laser Jammers. Very knowledgeable guy. Also resources on what's used and where. Also a very detailed website (https://www.vortexradar.com/best-radar-detectors/) With respect to filtering, things have changed a ton since you bought the V1. It has been 20 years since I regularly used a RD as well. With the Unidens (and some others I suspect), you can tweak and adjust just about everything about them. With the Vortex radar site, he provides FREE uploadable setting files so you can setup your radar exactly as he recommends if you don't have time or interest in learning all the various settings - this is what I did and another major reason why I chose Uniden (their upload process was easy to follow). Be sure to get a RD with built in GPS. With this feature, the RD will memorize where you continually get alerts and after a certain number of times/days of the same alert in the same location, it will automatically add it to the filter and not alert the next time. We live near a school zone with the speed reader signs that drive RD users crazy. After a couple of days, no more alerts....According to the Vortex site, the V1G2 does NOT have GPS except via an app on your phone and BT.
2023 X4 30i MSport BSM/Cognac 2018 BMW S1000XR & BMW R1200RT 2015 Yamaha FZ-09 Last edited by SpeedyATL; 07-07-2023 at 02:34 PM.. |
07-29-2023, 04:41 PM | #13 | |
Rep 107
Westside Guy5837.00 |
07-30-2023, 07:52 AM | #14 |
Rep 1,144
Drives: Z4 M40
Not sure of the definition of the car going to sleep, but I'll test this and see. I rarely use my RD so I'm not entirely sure. I believe it does turn off eventually but not sure how long.
UPDATE: Somewhere between min 4 and min 10 the RD turns off with the doors locked.
09-19-2023, 07:22 AM | #15 |
Rep 1,144
Drives: Z4 M40
This deal on the R4 just popped up on Amazon. This is the unit I have but I paid $50 more 5 months ago.
Great little unit with excellent range. https://www.amazon.com/R4-Long-Range...link=true&th=1
2023 X4 30i MSport BSM/Cognac 2018 BMW S1000XR & BMW R1200RT 2015 Yamaha FZ-09 Last edited by SpeedyATL; 09-19-2023 at 07:33 AM.. |
stlcdr1020.50 |
09-19-2023, 07:57 PM | #16 | |
Rep 16
09-20-2023, 05:07 AM | #17 |
Rep 1,144
Drives: Z4 M40
Pretty sure the power is cut as I'm not aware of a sleep feature on the RD.
09-21-2023, 03:49 PM | #19 |
Rep 480
Power stays on on my 2023 40i, I had to activate the auto turn off function, otherwise the RD was still on in the morning.
23' BMW Z4 M40i: Also Drive: 23' Tesla Model 3 Also Drive: 22' Nissan Frontier Pro 4X Waiting for 23' BMW Z4 M40i: |
09-21-2023, 08:48 PM | #20 |
Rep 16
09-27-2023, 12:34 PM | #21 | |
Rep 530
(M240i required 2 start button presses: 1 to stop the engine and 1 to turn off the rest. Z4 doesn't use the start button for the "turn off the rest" part.) |
09-27-2023, 02:30 PM | #22 | |
20192
Rep 8,573
There are two power wires going to the mirror one switched and one constantly on
Argo739.00 |
