03-18-2021, 10:24 AM | #1 | |
Rep 4,246
The More You Know: Integral Active Steering
Great new owner question on IAS in the G07 forums and since everyone is accustomed to my technical essays... errr... lengthy replies... I figured I should cross post here since the G05 shares technical features with G06 and G07:
TL;DR What you experience - it's all in the steering What you experience varies for different drivers - some may notice the variable steering ratio changes (direct / indirect steering feel) and others don't notice the change but sense that during turns steering wheel travel / feel's reduced or elongated. I'm in later category in regards to steering. Otherwise, you're not going experience IAS. What you actually get Slow speeds - from 5mph to 37mph, reduced turning turning by approximately 1m / 3.28ft in comparison with vehicles without rear axle slip angle control (HSR) High speeds - from 37mph and up, directional stability while driving and changing lanes THE LONG LONG LONG INTEGRAL ACTIVE STEERING EXPLANATION Electromechanical Power Steering with Variable Rack There's a component that's a part of IAS that is very rarely discussed which is the electromechanical power steering system with variable rack (front axel) as well as the rear axle slip angle control (HSR). The variable steering gear ratio in IAS is accomplished by the geometry/pitch of the toothed gear of the rack. Around the center position of the steering gear, the steering system behaves with steady directional stability. As the steering angle moves away from the center position, the ratio becomes increasingly more direct. Variable Steering Gear Ratio Front axle A) More indirect steering gear ratio in the center position of the variable rack (0° - 45°) B) Transitional range (45° - 130°) C) Direct steering gear ratio outside the center position of the variable rack (> 130°) X) Steering angle in degrees Y) Steering gear ratio in mm/steering wheel turn 1) Variable rack geometry (IAS) Steering Angle of IAS on the Front Axle A) More indirect steering gear ratio (variable rack geometry) B) Direct steering gear ratio (variable rack geometry) Rear Axle Slip Angle Control (HSR) The rear axle slip angle control (HSR) mounted on the rear angle permits a maximum steering angle of the rear wheels of +/- 2.5°. As a result, it was possible to reduce the turning circle by approximately 1m / 3.28ft in comparison with vehicles without rear axle slip angle control (HSR). The rear axle slip angle control is available from a speed of approximately 5 km/h / 3 mph up to the maximum speed. The request to adjust the steering angle at the rear axle is issued by the Dynamic Stability Control (DSC). A spindle drive inside the component is rotated via the electric motor. This produces a linear movement at the two track control arms. Using the position sensor, the control unit of the rear axle slip angle control (HSR) can determine the linear displacement and thus calculate the steering angle of the two rear axle wheels. The spindle drive of the rear axle slip angle control (HSR) is self-inhibiting. This means that the X7 has the identical drivability to a vehicle without rear axle slip angle control (HSR) in the event of system failure. SPECIAL NOTE WHEN GETTING ALIGNMENTS A special fixture is required for alignment in order to assemble the carrier plates. For this reason, the carrier plates on the rear axle slip angle control (HSR) must not be undone. If this is not observed, the wheel alignment on the rear axle will become incorrectly adjusted. Operation of Integral Active Steering A) Opposite steering B) Parallel steering In the speed range up to approximately 60 km/h / 37 mph, the rear axle slip angle control (HSR) steers in the opposite direction to the steering angles of the front axle steering. This permits increased vehicle maneuverability. As from the speed range of approximately 60 km/h / 37 mph, the rear axle slip angle control (HSR) steers in the same direction. This improves the directional stability of the vehicle. Driving control interventions when cornering When changing lanes quickly, all vehicles have a tendency to produce a significant yaw response and can sometimes start to oversteer. If the Dynamic Stability Control (DSC) detects a deviation between the driver wish and vehicle response, the vehicle is stabilized by means of a steering intervention at the rear axle. The speed of the stabilizing intervention is such that it is hardly discernible by the driver. It is possible to largely do without decelerating DSC brake interventions. As a result, the vehicle is more stable and the driving dynamics are preserved. If the driver underestimates a bend when driving rapidly, he may be surprised by sudden understeer. The rear axle slip angle control (HSR) can also perform a corrective intervention in understeer situations and thus additional increases active safety. Driving control on different surfaces Hard braking maneuvers on roadways that are slippery on one side make the vehicle yaw to the vehicle side with more grip. In the event of emergency braking, the driver of a conventional vehicle must take corrective action. With this so-called µ-split braking, the Dynamic Stability Control (DSC) provides a stabilizing yaw moment via a steering intervention at the rear axle. Further to A) Without DSC When braking with a vehicle without DSC, maximum brake force is supported on the dry side of the road and only low brake force on the wet or icy side. An anti-clockwise yaw moment is produced which can lead to the vehicle skidding to the right. Further to B) With DSC When braking with a vehicle equipped with DSC, the brake forces at the wheels are metered so that the yaw moment acting on the vehicle is reduced. The vehicle therefore remains controllable. The stopping distance may be increased slightly. Further to C) with DSC and rear axle slip angle control (HSR) When braking with a vehicle equipped with DSC and rear axle slip angle control (HSR) (optional equipment Integral Active Steering SA 2VH), the DSC control unit calculates the steering angle for the rear wheels. The actuators of the rear axle slip angle control (HSR) convert the calculated steering angle into an active steering angle at both rear wheels. The resultant stabilizing yaw moment allows the maximum brake forces to be applied in order to achieve the shortest possible stopping distance. The perfect interaction of steering and brake intervention therefore increases active safety and enhances the driving dynamics of the vehicle.
17
03-18-2021, 12:30 PM | #2 |
Rep 4,503
Drives: 2022 iX xDrive50, DGM
As an addendum, IAS in the Q7 reduces curb-to-curb turning radius by about three feet, likely similar in the X5.
03-18-2021, 03:50 PM | #4 | |
Rep 4,246
MY19-20 40i and 50i SAVs, IAS was an option in combination with air suspension or included with ZOR Off-Road package. IAS was removed for MY21 40i SAVs. MY20-21 M50i SAV, IAS is as an option in combination with air suspension or ZDH Dynamic Handling Package.
03-18-2021, 04:31 PM | #5 | ||
Rep 17
03-18-2021, 05:29 PM | #6 | |||
Rep 4,246
My replies are always contextual to poster's market and attempt to incorporate thorough market info in my posts but sometimes it just doesn't happen.
03-20-2021, 02:46 AM | #8 |
57
Rep 39
03-20-2021, 11:30 AM | #11 |
Rep 4,246
For USA markets, you'll need to consider a X5/6 M50i or X7 optioned with ZDH Dynamic Handling Package
03-20-2021, 12:11 PM | #13 |
Rep 144
I drove an X5 without IAS for the past 9 months. I'm on Day 2 of driving an M50i with DHP and IAS.
I don't know if it's the DHP or the IAS, but the steering feels far more precise and responsive. It feels like what I envisioned BMW steering should feel like. |
GrussGott18179.00 |
03-20-2021, 12:22 PM | #14 |
1165
Rep 1,778
I dont have DHP, but I do have IAS. and a F15 without IAS, and the difference is immediately apparently whenever I compare the two. the steering feels palpably way more precise.
Chapel Hill108.50 |
03-20-2021, 12:28 PM | #15 |
Rep 4,246
Here's in Norway, as mentioned earlier - for MY21 international markets continue to have IAS as an option.
03-20-2021, 12:39 PM | #17 | |
Rep 4,246
Since Bimmerpost is an international forum, it's my hope and request that members provide location context if required regarding options and features when they reply. It'll reduce confusion, clarifications or topic tangents.
03-20-2021, 01:55 PM | #18 |
Rep 236
What I don’t understand is most of the expert reviews on You Tube and the media say to avoid IAS like the plague and yet most of the owners on this forum seem very happy with the option. Maybe they are seeing it from a different perspective.
03-20-2021, 02:26 PM | #19 | |
Rep 289
funny how the "experts" are mostly those who will ever drive BMW during their 5mins press event moment only |
03-20-2021, 02:29 PM | #20 |
Rep 62
Not sure but many of those reviews slagging off the IAS was early, typ. 2019. Not sure but read somewhere they recalibrated it and definitely dont see so many negative comments in later reviews. After seeing too many self contradicting reviews from same magazines I dont place much trust in them. Merely an indication
04-13-2021, 07:42 PM | #21 | ||
Rep 774
Drives: 21 X5 M50i
-Matthew
04-13-2021, 08:09 PM | #22 | |||
20
Rep 44
