04-15-2021, 12:17 AM | #3 |
Rep 5,378
There's no doubt the S58 is a monster, stock or modified but how do we really know for sure that it can handle these power levels "all day long" without issue? The 1000hp+ drift car in question has only been running that power for a few weeks, no? What about 10K+ miles? There's no data.
BMW's track record with the plasma transferred wire arc (PTWA) thermal sprayed on liners in stock and modded B58s isn't so hot. If the liner becomes scored, you can't replace it as it's sprayed on. The S58 uses the same technology. The short block, and maybe even turbos, might be able to handle the power for a while, but what about all the other ancillary stuff like pumps, seals, cooling. heat exchangers, transmission, etc.?
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
04-15-2021, 03:16 PM | #4 | |
Obsessed with braking
39
Rep 82
Drives: 2015 BMW M3
An new engine development program from a major OEM is a $100M undertaking, and involves thousands of simulated (dyno) and actual (vehicle) engine durability tests. The fact that the S58 torque curve isn't so much a curve but a hard stop at 600Nm suggests that BMW intentionally capped the output in the name of durability, based on a substantial amount of data from their test program. A few drift cars that can survive a season (on maybe a 100-hour rebuild interval) isn't evidence that the engine could survive for any appreciable amount of time at 1000bhp power levels. |
04-16-2021, 09:49 AM | #5 | |
Rep 5,378
I'll also add that Vehicular DIY is a super knowledgeable guy and his videos are often exceptional. For this particular video/claim, I can't quite yet get there because there are too many unknowns. I'm sure the S58 will be "stronger" than the S55, but I'm not yet convinced this is the new 2JZ. Also, when it comes to the 2JZ, yes, the short block was strong as hell and the motor could make massive power BUT, to make massive power requires lots of ancillary upgrades. It seems like most people think you can just add a single turbo, make 800+whp on the 2JZ, and that's it. That couldn't be farther from the truth.
