04-18-2021, 11:48 PM | #1 |
2896
Rep 1,865
Don't put your rear wheels up front by accident...
I just changed from my winter wheels and tires (square 20" 740M wheels with General Grabber AT3 tires) back to my summer wheels and tires (staggered 21" 741M wheels with Pirelli PZero tires). It's been a while so I forgot the summer wheels were staggered and put one of the 10.5" wide rears up front. This resulted in the inner edge of the wheel rubbing against my upper control arm.
The powder coating on the inner rim is scraped and some small areas of bare metal is showing. I don't think any meaningful amount of metal was scraped off. It's not as bad as it looks in the photos. Do I need to have these powder coated again or just hit them with a coat of Rustoleum to protect the bare metal or just leave it and drive?
Current garage: 2023 Rivian R1S Adventure Forest Green/Ocean Coast, 2018 Porsche 911 T Carrara White Metallic/Black, 2019 Ram 2500 Big Horn Diamond Black/Diesel Gray
Archived: 2019 BMW X5 50i M Sport Mineral White/Full Black,2019 Ford GT350 Ford Performance Blue/Dark Slate, 2012 BMW X5 50i Alpine White/Black, 2014 BMW 320i M Sport Melbourne Red/Black, 2009 BMW DINAN3 Alpine White/Black, 2008 BMW 335xi Alpine White/Black, 1998 BMW 328is Avus Blue/Tan |
04-19-2021, 03:20 AM | #2 |
Rep 709
I would check the rim with a milling machine for roundness and to remove the sharp edges and mill the rim smooth. As it is the inside of the rim I would just spray paint them.
04-19-2021, 08:30 AM | #4 |
Rep 704
Maybe I'd suggest getting the two wheels re-balanced?
My question is, when you mounted the wheel onto the hub, did it not hit the control arm? Or did it only hit when you lowered the car which would have imparted some camber, only then hitting the control arm? |
04-19-2021, 10:54 AM | #5 | |
2896
Rep 1,865
The control arm looks OK. Just a little scrape where the wheel was rubbing. Maybe the real lesson here is that with a 5 mm spacer you could do a square 315 setup
phillydilles74.00 |
