10-31-2008, 02:24 PM | #1 |
BimmerPost Supporting Vendor
256
Rep 4,048
▀▄ eas | KW Variant 3 Coilover System for Your E92/E93 M3!
We'd like to take a moment and remind you that eas is an authorized stocking retailer of KW Coilovers for your e9X M3. This ensures you are getting our first rate service backed by KWs full warranty before and after your purchase.
The KW coilover suspension for the 2008 BMW M3 enables the owner to lower their vehicle 10-40mm on the front axle and 5-35mm on the rear axle and retains enough travel to handle maximum load and dynamic loads during driving. Variant 3 permits an even higher degree of customization to the suspension. Adjustable (and independent reacting) rebound and compression damping allows a truly individual performance driving setup for those technically demanding drivers. Compression dampening adjustment is conducted in the low-speed range, while the high-speed set-up, so decisive for driving comfort, has been pre set by KW engineers. 2008 BMW M3 models equipped with the optional Electronic Dampening Control (EDC) may utilize KW's code isolator unit. KW 's code isolator unit disarms the factory EDC while preventing unwelcome error codes to the factory ECU. Important characteristics such as safety, quality and performance are all taken into consideration with each KW coilover design. Each vehicle application is specifically designed and engineered for a proper range of motion, min/max weight loads and min/max lowering. All these requirements are met while retaining it's performance handling characteristics. Each KW coilover suspension is produced with unique stainless steel "inox-line" technology. The stainless steel construction internally and externally provides long term durability and corrosion resistance from the elements. All KW coilovers pass stringent German TUV safety and quality testing standards. Each kit is sold TUV approved. Features: - Independently adjustable damping technology -rebound and compression damping - "inox-line" stainless steel technology - Individual height adjustment - German TUEV-tested adjustment parameters - High-quality components for long life - Comprehensive documentation for ease of use - Infinitely adjustable rebound damping - 14- level adjustable compression damping - Unique, independently functioning damping power adjustment Applications: 2008+ e92 M3 Coupe 2008+ e92 M3 Convertible Note: vehicles equipped with Electronic Dampening Control will require code isolator units to prevent error messages Approximate Front/Rear Lowering: Front: 1.2" - 2.3" Rear: 0.8" - 1.8" KW Variant 3 Coilover System- BMW e92/93 M3 http://www.europeanautosource.com/pr...oducts_id=1910 If you have any questions please feel free to contact me directly via PM, email or just give us a call |
10-31-2008, 02:25 PM | #2 |
256
Rep 4,048
Here's a few pictures (including before and after pictures), of our installation of the KW Variant 3's on our E92 M3:
e92 M3 KW Variant 3 Coilovers EDC Code Isolators Installation: Before: After: If you guys have any questions please feel free to PM, email, post in the thread or give us a call |
11-03-2008, 09:16 PM | #4 |
8113
Rep 18,808
Drives: BMW
You have PM.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
12-01-2008, 03:20 PM | #10 |
Rep 2,091
PM me a price shipped to 98004.
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia 2020 BMW X7| Mineral White 2024 718 GT4 RS | Arctic Grey |
