Coolant Loss
05-22-2021, 03:44 AM | #1 |
Rep 3,219
Coolant Loss
Hi guys,
Recently been loosing about 1 litre of coolant a month. I can't see any leaks, the Water Pump has been replaced with a OEM one, including new radiator and hoses about a year ago. When I unscrewed the coolant expansion tank cap, i found the last thread had a chip/crack and the o ring was loose. Could this cause coolant loss, from engine heat etc? The windscreen washer fluid has been evaporating over a period of time as well, due to to cracks on the white plastic filler pipe, but that shouldn't be related. Last edited by Saif2018; 05-22-2021 at 07:26 AM.. |
05-22-2021, 08:35 AM | #2 |
Rep 105
I think that is possible. Since the system is pressurized the crack may only leak after the car is running. If you have the original expansion tank, it is very possible it is leaking at the seam. Mine was and had to be replaced 6mo ago. Looks for signs of leaks around the expansion tank is where I would start as this is a very common issue.
05-22-2021, 11:54 AM | #3 | |
Rep 3,219
05-22-2021, 10:09 PM | #4 |
Rep 105
Easiest way is to start the car, let it run for a min, then while it is running, look around the tank seams. That is the only place where I had a leak and it was slow
05-23-2021, 02:52 AM | #5 |
Rep 3,219
05-24-2021, 09:47 AM | #6 | |
Rep 3,219
05-24-2021, 10:10 AM | #7 |
Rep 3,053
Look for a dry white residue in the area of the ET, hoses and radiator. The coolant is blue but dries to a fine white powder.
05-24-2021, 12:25 PM | #8 | |
Rep 3,219
I'm hoping it's because of the O ring on the cap. |
