Upgrading from HiFi system. Questions
06-07-2021, 02:35 PM | #1 |
Rep 25
I currently have the HiFi system in my '11 E90 sedan. I'm planning on upgrading all the speakers and adding 2 10" subs along with a 4 channel amp and monoblock amp. I ant to keep my factory HU the way it is so my question is would I be able to splice the HU wires from the factory amp harness in the trunk?
Should I splice into the speaker wires and run them to the amps or should I splice into the HU wires that come from the HU to the harness that control the speakers? What is the difference in these wires? I am going off the pic that was stickied fo re90 wiring diagrams. See below. Thanks guys. |
06-07-2021, 10:15 PM | #2 |
1920
Rep 13,119
oops
You shouldn't splice anything buy a Technicpnp harness for Hi fi. https://technicpnp.com/ This will give you access to all Input and Output Wires without cutting anything. See the links in entry 3 in the following thread. https://www.e90post.com/forums/showthread.php?t=1831790 Last edited by ctuna; 06-07-2021 at 10:23 PM.. |
06-08-2021, 08:54 AM | #3 | |
Rep 25
06-08-2021, 12:05 PM | #4 |
1920
Rep 13,119
that is not a function of the harness . this is a function of the head
unit.(The OUtPUt of the Head Unit is differential) You can get double to single signal converters Although the reverse is more common. but most good amps will take either input. Check the amp specs . differential outs are like reduced speaker outs. Last edited by ctuna; 06-08-2021 at 12:21 PM.. |
06-09-2021, 06:59 AM | #5 |
Rep 80
Something like this: https://www.crutchfield.com/S-7tMcrl...saAm-CEALw_wcB
Hi-Fi | AudioControl D6.1200 & Crescendo-S1V2 | FiQ 12" | Morel MSW 265 8" | Morel MSW 114 | Dayton AMT Tweeters
06-11-2021, 02:06 PM | #8 |
1920
Rep 13,119
Read all of the first set of links in entry 3 of the provided link in this entry. |
