F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > 320Gt broken parcel shelf clips
GetBMWParts
      06-10-2021, 02:03 AM   #1
SerTan
SerTan's Avatar
45
Drives: BMW 320i M Sport F34
Ive done stupid thing when installed rear camera and placed my shelf that attaches to rear boot door wrong way round, and when closed the boot the lip of that shelf being wrong way round pushed on parcel shelf that right behind rear seats casing all 4 clips that coming from the body snapped.
Any solution to this? Ill try any DIY suggestions given Tried hot glue but it just comes off. How far do i have to dig to replace them? are they part of allot bigger piece of body panel?
As per image below this is where clips go in to the panel.
Mess with the Best - Die like the Rest
      06-20-2021, 12:41 PM   #2
SerTan
SerTan's Avatar
45
Anyone? Just need to know where the clips attach to, what interior body part to i ca see if can re replaced.
      06-20-2021, 02:09 PM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
We're all looking at the same realoem. The trunk trim panel shots there don't show the pins. You probably have to remove the trim panels to remove the original pins and devise replacements.
SerTan45.00
      06-20-2021, 03:26 PM   #4
SerTan
SerTan's Avatar
45
How easy of a job you recon to remove side trim panels? Thank you for reply.
      06-20-2021, 03:34 PM   #5
Billfitz
Billfitz's Avatar
It's not shown in my Bentley manual, but it's probably a combination of a few screws and a lot of clips. You'll need at least two plastic trim removal wedges and torx screwdrivers.
SerTan45.00
      06-20-2021, 03:39 PM   #6
SerTan
SerTan's Avatar
45
Appreciate, Will see if i can find somth online before i go ahead, always manage to break few clips
found this, guess its close enough
      06-20-2021, 04:01 PM   #7
Billfitz
Billfitz's Avatar
Required if you do your own work:
https://www.amazon.com/dp/B07L6FJGR4...roduct_details
      06-20-2021, 04:25 PM   #8
SerTan
SerTan's Avatar
45
      06-24-2021, 03:47 PM   #9
3-GT
Wales
333
Drives: BMW 320d GT
Looks as though you'll have to replace item number 3.
https://www.realoem.com/bmw/enUS/sho...diagId=51_8968
These instructions should help get you close enough.
SerTan45.00
      06-24-2021, 09:36 PM   #10
Billfitz
Billfitz's Avatar
I believe the pins in question screw or otherwise mount to those pieces, but without removing the trim that covers them I can't be sure.
      06-27-2021, 06:23 AM   #11
SerTan
SerTan's Avatar
45
Thanks for info guys. I didnt get to opening amd pulling trim panels off but as a temp i manage to use wide screws, cut head off, put some hardened silicon inside holes where pins broke off and screw them in. But will get it repaired properly.
f30post
