| 10-05-2021, 12:25 PM | #1 |
![]() 39
Rep 31
bimmertech audio upgrade
anyone have experience with the bimmertech upgraded amp? https://www.bimmer-tech.net/speakers...BoCLPsQAvD_BwE
Not sure what system am getting when I take delivery of my 2022 X5 soon but expect it won't be great. Thinking if I should buy the amp but want to know if there truly is a good difference that makes it worth it. Also be good to know if it is very easy to install as represented. |
| 10-05-2021, 12:36 PM | #2 | |
![]() 236
Rep 265
There is a massive discussion here on upgrading the base HiFi sound on the G05. Many say a Amp upgrade alone is the best option. Others say speakers first. I've done neither but interested so following....
https://g05.bimmerpost.com/forums/sh....php?t=1830327 Generally there are Three nuances I'm reading: 1. The upgrade process for 45e vs. other X5's is different. (not sure on the exacts yet...just FYI). 2. The speaker upgrade alone has a repercussion of needing to crank the VOL UP really high to hear it as good? 3. The AMP upgrade has the repercussion of making your blinkers and all vehicle bells/warnings really loud. - I gather there are fixes for #2 & #3, but it's not straight forward... Quote:
| 10-05-2021, 01:10 PM | #3 |
![]() ![]() ![]() ![]() 633
Rep 948
Amp and/or subs are more involved. Speakers are more straight forward. I was a bit skeptical about just upgrading the speakers. After some reading/watching, I decided to do the upgrade. It's more than adequate for me now. I don't feel the need for sub/amp (yet)
If you end up doing amp, you may want to swap out the speakers as well. As you see, they look pretty bad compared to the Bavsound's. |
mereso38.50 |
| 10-05-2021, 03:00 PM | #5 |
![]() 39
Rep 31
Info on your other post was excellent - thanks for that. I will likely use a professional installer am so not good at any DIY stuff (as in my hands can be as lethal as a WMD on most things).
| 10-05-2021, 10:26 PM | #6 |
Rep 1,368
I recommend getting these speakers/subwoofer if upgrading the HiFi system and you will notice a very significant improvement. You can find them for about $1000 from a European distributor. Not shown in the picture is the second subwoofer.
| 10-06-2021, 06:52 PM | #7 | |
Rep 2,810
On YouTube Paul McGowan, from PS Audio talks about which component you should upgrade first…Paul has been in the audio business for a long time and highly respected Just replacing the door speakers will improve the highs and mid range clarity. Which to me is the biggest problem with the HiFi system. |
| 10-07-2021, 01:48 AM | #8 |
17866
Rep 11,728
Drives: 2022 X5M
I don't really agree for a car audio system due to the environment (it's complicated, depends on goals blah blah blah), but I'm still appreciating it for referencing Paul ... he's pretty controversial. Many in the hi-fi world think he's a shyster, and few reputable people claim to have gotten burned by him and refuse to have anything to do with him. Nevertheless, in my experience, he's a good guy ... maybe a little Elon-y, but well intentioned.
skiboy39.50 |
| 10-07-2021, 08:21 AM | #9 | |
Rep 2,810
GrussGott17865.50 |
| 10-07-2021, 12:01 PM | #10 | |
Rep 948
| 10-07-2021, 01:01 PM | #11 | |
![]() 54
Rep 148
I also wonder if the under-seat subs are all equally junk vs a bigger trunk sub and thus, is the under-seat sub upgrade very marginal. |
5pacey68.50 |
| 10-07-2021, 01:05 PM | #12 | |
Rep 153
| 10-07-2021, 01:21 PM | #13 | |
![]() 54
Rep 148
SUB4 - With its 4 Ohms impedance, it is ideal with your orignal amplification SUB2 - With its 2 Ohms impedance, it perfectly associates with the FIT 9.660 amplifier/DSP. |
5pacey68.50 |
| 10-07-2021, 02:04 PM | #14 | |
Rep 153
| 02-22-2022, 04:07 PM | #17 |
![]() 20
Rep 33
Are these a direct swap?
| 02-22-2022, 05:40 PM | #18 | |
Rep 1,368
| 03-05-2022, 01:44 PM | #19 |
Rep 20
I am thinking of replacing the subs as well...was it ever determined if in the G05 with 676 AND the Match DSP/MEC amp upgrade should you use 2 or 4 Ohm? Thanks for the patient response!
| 03-05-2022, 11:52 PM | #21 | ||
Rep 78
Yes the speakers are definitely a major change but when you add the amp in, it really shines. Also Bimmertech is great customer service and they have been very helpful in providing tune files to get it just the way I want it. Then have worked hard and quick to make minor changes based on how I have commented on any tune they sent. I can not recommend then enough and everyone that has heard it has been wow'ed. Definitely zero distortion and amazing bass and highs. My settings for bass and treble in the car is set to neutral now and the car sounds rocks! |
Tch-Nrd151.00 |
| Bookmarks |
