10-29-2021, 12:58 PM | #3 |
Rep 263
Do you know the center bore and bolt pattern of the new wheels? Do they match oem?
Oem ET is 20 front/rear and have the same widths as the wheels you are proposing. To match the oem look you will need spacers, especially in the rear(15mm). For a flush look a little more aggressive than oem you would need something around 15mm front and 25mm rear on those wheels. Here is a great calculator tool I like to use. https://www.1010tires.com/Tools/Wheel-Offset-Calculator |
