| 12-18-2021, 09:28 AM | #1 |
Rep 236
Wind noise from driver window/door
I recently started getting a loud wind or whistle noise from the driver side window or door (couldn't pinpoint yet) anytime the heating is turned on and driving over 30km/h. It seems to go away significantly when I turn off the heating while driving.
Anyone ever experience this? Thanks! |
| 12-18-2021, 11:41 PM | #3 | |
Rep 236
I found an SIB on google somewhere pointing to the trim on both sides of the windshield; https://static.nhtsa.gov/odi/tsbs/20...75279-9999.pdf I checked them out, they seem a bit loose at the top but not detached as per the photo here. It has honestly become so prominent that I am constantly hearing it even with the music on and still debating whether to take it in or try to get used to it. |
| 12-20-2021, 08:13 AM | #4 | |
![]() ![]() ![]() ![]() 172
Rep 619
| 12-20-2021, 09:23 AM | #5 | |
Rep 9
Anyway, the seal for the sunroof didn't look like it went all the way across. New X5's on the lot weren't the same, so they replaced it. Fixed the issue. |
maher166.50 |
| 12-24-2021, 10:55 AM | #6 | ||
Rep 236
You are right! I was always wondering why that seal running across the tilting part of the sunroof had a gap on the driver's side, every time I wash the car. This morning I closed the gap with a piece of tape and the noise went away. This confirms that the wind noise is coming from there. I'll mention this at my next service. So for anyone suffering from wind noise appearing to come from the driver side window or door, check that seal for any gaps first. |
thereef5103094.50 |
| 12-24-2021, 03:32 PM | #8 |
Rep 2,930
Drives: see garage
Garage List 2023 BMW i4 eDrive35 [0.00]
2024 Porsche 911 C2S [10.00] 2025 BMW Z4 M40i [10.00] 2020 BMW X5 40i [10.00] 2016 BMW X5 35i [10.00] |
i also have this sound and have had it since the beginning. can someone please take a picture of the specific area and where to put the tape so i can test it out too? thanks!
| 12-24-2021, 03:33 PM | #9 |
Rep 236
thereef5103094.50 |
| 12-24-2021, 04:52 PM | #10 |
Rep 236
Here's the picture.
| 12-24-2021, 04:56 PM | #11 |
Rep 2,930
Drives: see garage
I can't really orient myself to your car from that picture, is the encircled part over the driver seat? where did you put the tape? on the outside or the inside? can you take a picture of that part please?
| 12-24-2021, 05:31 PM | #12 | |
Rep 236
Here's a better picture to give you a better idea. The tape is just temporary to test it out and since this morning the noise is gone. |
| 12-24-2021, 05:33 PM | #13 |
Rep 2,930
Drives: see garage
thanks, that's a lot better, I'll definitely try it out and if it works, i'm gonna tell the dealer to fix it. I've basically lived with that little hiss for the past two years.
| 12-24-2021, 05:35 PM | #14 | |
Rep 236
Let me know if it works out for you as well. Happy holidays! |
thereef5103094.50 |
| 12-25-2021, 11:30 PM | #15 |
Rep 236
I tilted open the sunroof and this rubber seal is easily moved from side to side when you grab it. It seems to be a defect along with the fact that it isn't long enough to cover both ends at the same time.
| 01-03-2022, 03:45 PM | #16 |
![]() 46
Rep 83
Has anybody had this seal replaced. Mine is short as per the photographs above. It is definitely causing a whistling noise in the cabin as when it is taped over the noise goes.
The seal moved left and right easily but can’t work out how to replace it. Definitely going to highlight it at the next service due at the end of the month |
| 01-03-2022, 08:59 PM | #17 | |
Rep 236
kkratochvil378.50 |
| 01-20-2022, 06:48 AM | #18 | |
Rep 9
Sorry for the late reply! |
kkratochvil378.50 |
| 02-13-2022, 11:08 PM | #19 | |
Rep 514
I'd noticed wind noise a couple of times last Winter (Winter of '20/'21) when it was really cold, but when things warmed up, it went away and I never noticed it again until it got cold gain this Winter, back in November. Also, as maczrool mentioned, I too heard the ticking sound when it was cold. I could never put my finger on it, but I always thought it sounded like leather on leather rubbing or movement where it would "stick" a bit...I never equated it to the sunroof. After reading this thread I took a closer look and found the same gap others had noted. (See pic below) Similar to others, I could easily slide the seal when the sliding roof was in the "up" position. When I first found it, the gap was on the driver's side. So, I slid the seal to put the gap on the passenger side and sure enough, the wind noise "moved" to be much more prominent above the passengers head. I brought the issue to the attention of my SA when I had it in for an engine coolant issue and my dealer quickly found and additional SIB that had been posted just last November: SIB 54 04 21. (Note: This SIB is different than the one posted earlier in this thread.) Effectively, the SIB simply indicates to install a new seal (Part #: 54-10-7-493-155) and then use a bit of Loctite on each end to keep the seal in place. This completely eliminated the wind noise I was hearing, as the cabin is much quieter now! It also completely eliminated the ticking noise I would hear when it was really cold out. I wish I would have had it dealt with a couple of months ago, because it's amazing how big of difference it made. (You get used to wind noise over time...)
2020 BMW X6 (G06) M50i - Manhattan Green/Coffee - 03/2024.47
Last edited by kkratochvil; 02-13-2022 at 11:15 PM.. Reason: Added additional detail RE the seal repair also eliminating a "ticking" noise. |
| 02-14-2022, 07:27 AM | #20 | ||
109
Rep 336
Drives: MY19 X5 40i
Brandan
What?s next ? BMW X5 40i Audi Q3 Toyota Corolla S Nissan Murano |
| 02-14-2022, 08:39 AM | #21 | |||
Rep 514
Effectively, the SIB gives the service department a pre-approved or "no hassle" piece of warranty work, which they tend to not want to turn down… With some SIBs, it can be a bit challenging to demonstrate they apply, but with this one being a seal gap that is easily visible and a customer complaining of wind noise, it should be a "no brainer" for most.
SKBSY8108.50 |
| 09-13-2022, 02:56 PM | #22 |
![]() 141
Rep 219
I just had this fixed for my MY22. Note that the SIB mentioned in this thread is only covering Aug '17 - Dec '20 vehicles. I had to have some back and forth with the SA because he initially told me this wouldn't apply to my vehicle. But once he saw the vehicle himself and we compared it to another X5 on the lot, things moved on fast. I wonder if there is an another SIB with updated dates out there.
I2P41.50 |
| Bookmarks |
