ZPOST
  TireRack
      11-24-2008, 02:31 PM   #1
Spaceman Spiff
Drives: R8, 996 C2, Z4MR (sold)
Z4 carputer
I was wondering, has anyone here installed a normal computer in a Zed? The navigation screen looks very decent for a computer and given the far out-dated functionality of the nav system and otherwise lack of robust entertainment, a computer can be a sweet addition!
      11-24-2008, 09:23 PM   #2
ATX750i
ATX750i's Avatar
Drives: 2009 Honda Civic Si
2003 Z4 2.5i  [0.00]
How would one go about such a mod and how practical would its uses be while moving down the road?
Johnathan
03' 2.5i Maldives Blue Roadster - SOLD
09' 2.0 Polished Metal Metallic Honda Civic Si - Current
      11-25-2008, 01:57 AM   #3
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
It would be good if we could tap into the screen.
You could use it play dvds, hook up parking cameras, display engine read out info.
I dont know if it has any video in connections that we can plug a carputer/other devices into.
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      11-25-2008, 06:53 AM   #4
O-cha
O-cha's Avatar
218
Drives: Mcoupe
You can with an auxiliary module, and somewhat without one as well as far as I know.
      11-25-2008, 08:44 AM   #5
nate96
44
Drives: TI Silver 06 Z4 Coupe
There are ways to tap into the factory screen. I did alot of research on this last year, but gave up cause I could not find a screen. There is a lot of cool stuff you can do with a carputer especially in a BMW with ibus, as everything is run of codes (IIRC it is HEX or something). If you want to do this, do alot of research. www.mp3car.com is a good way to find information on this. You can run GPS, MP3, movies, Bluetooth phone all off the carputer.
This guy took a Z4 Screen and a carputer and put it in his 540i.
http://web.mac.com/jlitko/iWeb/BMW%2...5E0706921.html
http://www.mp3car.com/vbulletin/work...-part-2-a.html
http://web.mac.com/jlitko/iWeb/BMW%2...0Part%202.html
http://www.bimmerboard.com/forums/posts/142176
      11-25-2008, 12:30 PM   #6
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
hmm. I spy russian writing in your avatar.
      11-25-2008, 02:33 PM   #7
Spaceman Spiff
Basically what J Factor and Nate96 said: you will have access to a whole array of entertainment options, internet, a good GPS, etc. I retrofitted the factory nav a few months ago and the lack of fuctionality is just pathetic! A sub-$100 GPS does much more than what this system does.
As for HOW, I was thinking either through a video module (i.e. you add a video module to the nav system and connect the computer via A/V input) or even the more elaborate way of tapping directly into the IBUS as Nate96 mentioned. There's this guy who also makes an IBUS to USB module:
http://www.reslers.de/IBUS/
and here's an example of what can be accomplished with it:
http://web.comhem.se/bengt-olof.swing/CarPCProject.htm
      11-25-2008, 02:55 PM   #8
561design
z4um Hooligan
561design's Avatar
Jamaica
140
Drives: 3.0Si
Or you could go this route...
What you would need is an Mini-ITX Computer.
The whole computer is siting to the right of the CD case.
More info here.
http://damnsmalllinux.org/store/Mini..._Small_Machine
You can buy a starter bundle here.
http://www.mini-itx.com/store/?c=44
Charles
flickr
      11-25-2008, 03:03 PM   #9
nate96
44
You do not need to go with after market. If you search around (I think on the link I provided) is a way to connect to the factory. But with an after market you would get a better screen, touch screen if you wanted. The possibilities are endless, depending on how inclined you are.
On ebay you can find some carputers that just require installation.
zpost
