BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    New dinan coilpacks
      01-09-2022, 08:30 PM   #1
Eljeffrey13
Eljeffrey13's Avatar
Drives: Bmw f90 M5
New dinan coilpacks
Seen that dinan released new coil packs in different colors and claiming to have 10% more energy output than stock, price also isnt bad, wondering if ppl are planing on getting these instead of oem for maintenance?
Jeffrey jaquez
      01-09-2022, 08:53 PM   #2
pbonsalb
5234
Drives: 18 F90 M5, 99 E36 M3 Turbo
At 50-100k miles on a modified car, they could help and if they are in the same price range as OEM they are worth considering.
      08-06-2022, 01:22 PM   #3
JetDriver
Drives: No BMW yet :(
You can pretty much by 2.5 of the Dinan coil packs for the price of one OE ($28 vs. $74). Seems like a no-brainer if you're replacing yours.
      08-07-2022, 08:12 AM   #4
Jakerx
Jakerx's Avatar
701
Drives: F90 Comp
Just be advised that they currently need modification to work with our engines, so once you modify, there’s no warranty or return.
      08-07-2022, 09:38 PM   #5
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Originally Posted by Jakerx View Post
Just be advised that they currently need modification to work with our engines, so once you modify, there's no warranty or return.
What modification would that be and by whom? Fits my N63 just fine.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      08-08-2022, 07:11 AM   #6
JetDriver
After reading through Dinan's stuff, it looks like the modification may be to the actual coil and not to the vehicle.
https://documents.dinancars.com/dina...oil_faq_r2.pdf
Jakerx701.00
      08-08-2022, 10:39 AM   #7
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
Correct. Its a locating tab that is designed in the coil that needs to be shaved off to be compatible for most N63TU/S63TU applications. While the black coils will likely need the modification for awhile (still lots of stock) the red/blue ones are switching over to a tabless design where modification of the coil will not be needed. Just waiting on that replenishment stock to arrive.
Appreciate 3
Jakerx701.00
JetDriver107.00
isenc2146.50
m5post
