01-16-2022, 11:41 AM | #1 |
Rep 131
Is it OK to have uneven PSI in one of your tires?
For some reason, one tire has always had 1 or 2 PSI off on the sensor readings.
It is ALWAYS the front right tire that seems to bee off by one or two PSI in the values. Is there a reason for this? It's been like this for years regardless of new tires. |
01-16-2022, 09:04 PM | #3 |
Rep 131
Yes! I am only reading it off the sensor readings from the iDrive menu. My front right tire always fluctuates. Is there any possible underlying issue for this? It has been like this for years
01-16-2022, 10:05 PM | #4 |
Rep 3,190
You should check the pressure at the tires. The tpms sensor is probably just not calibrated correctly from the factory.
simplyeric70.00 |
01-17-2022, 12:59 AM | #5 |
Rep 6,053
