      03-24-2022, 03:50 PM   #1
elite-fusion
Drives: 335xi
JB4 Install - How To?
Hey everyone,
I just got my JB4 in the mail and want to take this on over the weekend.
How hard/easy is it to do?
Any tips from those who ran this?
How to get from inside the cabin to the engine bay?
I remember on my E92 it was fairly easy to install, max of like 30-45 minutes, not sure if the G05 is the same.
Any help would be greatly appreciated
      03-24-2022, 05:10 PM   #2
AlpineG05
hi
AlpineG05's Avatar
748
Drives: Alpine White G80 Comp
Originally Posted by elite-fusion View Post
Hey everyone,
Pretty easy to install just run the OBD cable through the hood latch cable grommet. FYI, it's a tight fit causing the grommet to rip a bit.
I also ran JB3 on my e90 335 (n54 motor)
2022 M Sport G05
Jb4, CTS catless dp, M performance exhaust, bms intake, IND goodies, Maxton kit
      03-25-2022, 09:28 AM   #3
elite-fusion
Drives: 335xi
Thanks
Also saw that there was a way to route it through the outside door into the fender and into the engine bay.
Side question though for AlpineG05,
I see in your signature you have some goodies which I would like to get.
I have a '19 xDrive50i so not 100% sure if you'd know this or not, but would your goodies (Intake and DP) fit the 2019 G05 xDrive50i
So it did not go according to plan. I took the metal brace off, metal plate up front, the side plastic covers, took the intake gromet off, pulled back the plastic hose underneith the grommet, but was unable to locate the tmap sensor.
Does anyone have pictures or guidance of where I can locate it from both sides.
      03-29-2022, 07:32 AM   #4
totalone
Drives: x5 e45, M440
Has anyone attempted running through firewall?
      04-02-2022, 08:51 PM   #5
elite-fusion
Drives: 335xi
Finally installed. did not need to remove anything except the 2 front braces and the plastic side panels. Did not need to remove the intake grommets and air duct tubes. I was able to get my hand in on both sides without too much issue.
The EGW plugs have been left unplugged for now since yeah, its hard to get to them, plus the turbos were HOT so I wasnt really able to get in there too easily.
the driver side is decent, I was able to get it unplugged and would probably be able to connect the JB4 connector, but the passenger side was a no go due to the turbo being too hot.
Also, I did NOT route through the firewall to avoid any rips/tears in it due to the plug size, instead routed it through the door jam > through fender> to the compartment where the JB4 unit is mounted.
Did not feel like fiddling with the firewall grommet and poking holes, etc... I was thinking of gutting the end plug off of the OBDII cable that plugs into the JB4, routing the wire through the firewall hopefully without ripping it, and then reattaching the wire to the plug in the engine bay, but too much work, so just routed it through the fender to allow for an easier uninstall.
      04-04-2022, 11:48 AM   #6
Tagajjar
Drives: 2011 BMW X3
I haven't installed mine yet but that's probably the way I'll run it too. Not sure why they can't make a bluetooth obd or something that would work.
Or have it operate without needing to be plugged in once you set map.
      04-04-2022, 12:29 PM   #7
elite-fusion
Drives: 335xi
And that is what I was thinking too because i am not 100%sure that you need to keep it plugged in once map is set, but I could be wrong since I have not tried it.
      04-04-2022, 07:31 PM   #8
AlpineG05
hi
AlpineG05's Avatar
748
I believe the OBD not needed, but definitely recommended. I remember reading about it on the n54tech.com website.
2022 M Sport G05
      04-05-2022, 11:42 AM   #9
Kobe4Ever
Drives: 2019 X5 50i
Hey everyone,
Cant wait to see your feedback!!! Make sure your spark plugs are NGK .2 gap and might as well swap your ignition coils as well!
      04-05-2022, 11:44 AM   #10
elite-fusion
Drives: 335xi
Have driven it too much since installing, just maybe a 5 to 10 min drive.
Did not swap plugs or coils as I have never done that in the past.
Is this something that I can do myself?
If so, please link to what I need.
      04-05-2022, 07:39 PM   #11
Kobe4Ever
Drives: 2019 X5 50i
Gotcha- what map have you tried abs what are your impressions for throttle response, etc??
Well it’s impossible for me to say exactly what your car needs at this very moment it’s just generally a good idea to do ignition coils and spark plugs with a tune!
      04-06-2022, 05:23 PM   #12
elite-fusion
Drives: 335xi
So i found these:
https://burgertuning.com/products/ng...nt=42124774926
Assuming that is what I would need under higher boost for them to not run as hot as OEM.
Do you happen to know what ignition coils would be good?
      04-07-2022, 07:43 AM   #13
Kobe4Ever
Drives: 2019 X5 50i
So i found these:
There’s no need for special ones, the factory OEM ones are perfectly fine they just need to be replaced at 20 to 30,000 mile intervals when tuned!
      04-07-2022, 07:49 AM   #14
elite-fusion
Drives: 335xi
My car only has <10k on it currently, so i guess only spark plugs it is
      04-08-2022, 06:48 PM   #15
Kobe4Ever
Drives: 2019 X5 50i
Yes I think just plugs for a while! Please let us know your impressions with the JB4 !
      04-08-2022, 10:00 PM   #16
elite-fusion
Drives: 335xi
Any tips or pointers on how to change plugs? Any guide to this on the G05? Dont even know where they are located nor what tool would i need.
      04-09-2022, 08:29 AM   #17
Kobe4Ever
Drives: 2019 X5 50i
I know you should gap them to .2 - there are a few YouTube videos on it I believe it’s fairly simple hand tool stuff!
On a side note, I’ve been REALLY debating to do full tune/ downpipes/exhaust and X5m carbon intake retrofit, but along with that I’ll have to do plugs/coils etc and the other things I mentioned above! I’ll be creating a build thread if/when I do it!
      04-13-2022, 09:27 AM   #18
Tagajjar
Drives: 2011 BMW X3
Where did you mount the box?
      04-13-2022, 10:14 AM   #19
elite-fusion
Drives: 335xi
Per instructions, under the plastic cover on the drivers side of the hood. I ziptied it to the hole where the cover pops and locks into.
      04-13-2022, 08:57 PM   #20
Kobe4Ever
Drives: 2019 X5 50i
What maps have you driven the JB4 on so far!? How much of a performance increase are you experiencing?
      04-13-2022, 09:09 PM   #21
elite-fusion
Drives: 335xi
Stillbonly map 1 as i have not driven much hobestly. I want to give map 2 a try but i want to get logs over to the N54 guys first to have them tell me if map 2 or a custom map would be good or not.
Also, dont have any E85 by me unfortunately
