BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Sunroof popping sound
      04-10-2022, 11:56 PM   #1
jivom5
Drives: audi a7, c7 grandsport
Has anyone had any issues with the sunroof, mines making a ton of noise from the back right side, dealer wasn’t able to reproduce the sound but it’s very noticeable
https://www.youtube.com/shorts/Lknx3jBUby8
      04-11-2022, 01:40 PM   #2
MB625
MB625's Avatar
Drives: BMW M5 Comp. LCI
I’ll post a video soom
Does it sound like a slow rainfall hitting the glass? If so, a clean/replacement of the rubber seals did the trick for me.
      04-11-2022, 03:48 PM   #3
jivom5
i uploaded a video, happens when the sunroof is open/closed/tilted/shade open/closed.
already applied wd40 to every joint,seam,everything and its still there and seems to be louder now
      04-11-2022, 04:04 PM   #4
GranitM5
GranitM5's Avatar
366
Drives: 2018 BMW M5
WD40 is water based. It is not an actual lubricant even though it's sometimes used as that. I would try a silicone based lubricant. Should do the trick.
      04-11-2022, 04:06 PM   #5
jivom5
video posted, does not seem like its related to the seal itself
      04-12-2022, 07:01 PM   #6
jivom5
update: it seems to be the black plastic piece attached to the body of the car
      05-17-2022, 05:27 PM   #7
vanos84
vanos84's Avatar
66
Drives: 2018 M5 BSM
I swear I did not even know that you could get these with a sunroof, lol. I Thought they all came with the solid carbon fiber roof panel.
      05-24-2022, 03:28 PM   #8
jivom5
if i could go back i wouldn't have purchased this car with a sunroof... the rattling is making me want to get rid of this car
      05-24-2022, 03:32 PM   #9
MB625
MB625's Avatar
At least you don't have the pervasive exhaust rattle...
      05-25-2022, 01:48 PM   #10
jivom5
i posted a fix for that, any exhaust shop can repair it in less than 5 minutes
      05-31-2022, 04:42 PM   #11
Antec800
Drives: 340i x drive
It’s a known problem dealer needs to lubricate the seals
m5post
