04-30-2022, 04:14 PM | #1 |
Rep 488
Turbo wear OK?
I fitted an MST inlet the other weekend and took a picture of the turbo whilst the inlet was off.
The turbo looks to have seen some dust particles from the wear on it - I have been running a pipercross drop in filter (which is an oiled foam filter) for about 2 years. However, is this level of wear ok/normal, or should I be sticking the oem filter back in? Thanks. |
04-30-2022, 04:38 PM | #2 |
Rep 3,703
Ouch. This is why I don’t even run the aFe dry drop in filter. Stock paper filter only for me. Both my stock and Dinan turbos looked pristine when they came off my car.
I’ll let others comment on the impact of the impeller wear. |
04-30-2022, 04:54 PM | #4 | |
Rep 488
The engine is still making really good power, so I don't think that the wear is enough yet to affect the performance, but run like this for a few more years and the blades could start to change shape I guess. Don't want that to happen so the oem filter wok be back in tomorrow. |
04-30-2022, 05:03 PM | #5 | |||
Rep 7,470
+1 Quote:
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
widetyres280.00 |
05-01-2022, 06:46 PM | #7 |
Rep 4,173
This is pretty extreme assumptions being made. People have run intakes on these cars and PWGs for over 10 years, and how many people have seen their turbo go? I would say it’s an issue that could have been there before the intake, and if it’s from the intake - no one stateside uses a foam filter.
///M TOWN20214.50 |
05-01-2022, 07:36 PM | #8 | |
Rep 7,470
Pre turbo water injection damage:
chris7197357.50 |
05-01-2022, 09:12 PM | #9 |
Rep 4,173
Sounds like he over oiled and/or installed a wet filter on his car. That, and foam filters have always been garbage in my opinion, but the guys overseas do things I find irrational, like dyno with the hood down
https://f30.bimmerpost.com/forums/sh....php?t=1830358 Oil thread here doesn’t indicate any high amounts of insolubles in the oil of anyone with an intake, and they are actually lower than the universal average. I would assume this is a one off, since many people have installed inlets, and this isn’t a common image. The sound and throttle response, not even the power increase (which is there) was enough for me to take my intake over the stock box/paper. But to each their own. |
///M TOWN20214.50 |
05-02-2022, 08:53 AM | #10 |
Rep 4,173
https://www.e90post.com/forums/showthread.php?t=1779483
https://www.triumph675.net/threads/a...-filter.40100/ Pipercross is garbage, throw it out and go with an AFE dryflow. No need to go back to the paper filter. |
05-02-2022, 09:05 AM | #11 |
Rep 3,703
The rub here is no one has shown significant (or any) gains with aftermarket intakes or filters vs the stock M2 intake, just more noise if you’re into that kind of thing.
And silicon increased in my oil analysis when I ran the aFe dry filter. So if there’s no major added power, and there’s potential for contamination, why run it? Simply for the vanity of added sound or showing off under hood looks? That’s quite a trade off. |
F87source7309.00 |
05-02-2022, 10:53 AM | #12 | |
Rep 4,173
Again, 10-20wtq is not worth it to some, but for me it makes driving more enjoyable. To each their own. Last edited by AmuroRay; 05-02-2022 at 02:11 PM.. |
05-02-2022, 11:00 AM | #13 |
Rep 647
I find it interesting you’re so data driven in your analysis of intercoolers, yet claim 10-20wtq from an inlet and intake without data to support it.
I haven’t seen this verified on dynos with the hood up, or down Last edited by ///393; 05-02-2022 at 11:05 AM.. |
05-02-2022, 11:03 AM | #14 | |
Rep 3,703
So, it’s all risk, no reward. |
05-02-2022, 11:07 AM | #15 | |
Rep 3,703
The M2 intake is good to go from the factory, unless you’re pushing Stage 3 like power & boost. Plus, it gives better under hood hot air, water, and dirt protection than all the aftermarket options. |
///M TOWN20214.50 |
05-02-2022, 12:39 PM | #16 | |
Rep 7,470
///M TOWN20214.50 |
05-02-2022, 01:47 PM | #17 | ||
Rep 4,173
https://f87.bimmerpost.com/forums/sh...9#post27948519 https://f87.bimmerpost.com/forums/sh...1318580&page=3 BMS: Independent test by Bimmerworld (on their product webpage) M2 vs Injen intake Independent test by forum member New evidence: https://f30.bimmerpost.com/forums/sh...1710794&page=3 Quote:
Intakes are absolutely more effective with a inlet installed, which itself was good for 10whp per BeePee and 3t3p’s independent dynos. In terms of more dirt/silicon found in the samples - I haven’t seen any significant variations in terms of dry vs paper, but feel free to post examples. Last edited by AmuroRay; 05-02-2022 at 02:12 PM.. |
///M TOWN20214.50 |
05-02-2022, 02:03 PM | #18 |
Rep 4,173
The inlet dyno graphs:
Pre vs Post mst inlet, turbo smart Diverter, and intercooler 412hp to 421hp - 9hp https://f30.bimmerpost.com/forums/sh...1&postcount=20 395hp to 405hp - 10hp (pure inlet) |
///M TOWN20214.50 |
05-02-2022, 04:08 PM | #20 | |
20215
Rep 8,574
I learned about foam filters being insufficient when I was running a HKS bell style foam filter on my Honda engine and found sand like debris inside the path to the throttle body after a friend told me to look for it… He was right! I immediately removed and sold the HKS and I returned to a stock airbox and a dry filter
05-02-2022, 04:17 PM | #21 | |
20215
Rep 8,574
The T~inlet is clearly the bottleneck
widetyres280.00 |
