2007 E92 335i - White smoke out of intake
07-18-2022, 03:38 PM | #1 |
Rep 2
Hi guys,
Hopefully someone can shed some light on this. Started noticing white smoking coming out of my the rear intake cone on startup, and revving. There is nothing coming out of the front cone. Anyone got an idea what could be causing this? Video with the cone removed: https://www.youtube.com/shorts/SYH8hTlTRi0 Video with the cone installed: https://www.youtube.com/shorts/_kQrJVjeaMs Current Mods Pure Turbos Stage 2 DD 450-600 VRSF 2'' N54 high flow silicone inlets VRSF N54 Catless Downpipes Wagner Evo 1 Competition Intercooler BMS N54 Dual Cone Performance Intake VRSF Chargepipe Turbosmart BMW N54 Plumb Back Recirculating BOV Fuel-It BMW N54 & N55 Stage 2 LPFP Low Pressure Fuel Pump RB BMW N54 PCV Valve 3.5 Bar TMAP Index 12 injectors New HPFP |
07-19-2022, 12:11 PM | #2 |
Rep 3,731
Isn't that pressurized air coming from the turbos where the BOV feeds back into the intake tube? It's going to dump the pressure from the turbos after you rev up the motor and then let off the gas....to dump pressure when you let off of the throttle.
When pressurized air goes to normal atmospheric pressure, you're going to see some white "fog" when moisture forms. No different than opening the air valve on and air compressor......
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
