09-13-2022, 06:13 PM | #1 |
Rep 478
Auto start/stop disable.
On the year 2022/2023 X5 40i models, since they removed the auto start/stop button. Is there any way to disable it without having to place the vehicle in sport and drive around in the firm suspension setting, any other way around it?
2023 BMW G05 X5 xDrive40i
2023 BMW G30 540i |
09-13-2022, 06:33 PM | #2 |
Rep 184
Drives: 2024 X5 40i
Code it or have it coded for you. You could also try setting up a Sport Individual setting with "Comfort" as the selected suspension setting (see the Manual for the how to). You'll still need to put the vehicle into Sport Individual when you start the vehicle, but you'll have the suspension mode you prefer. There are other posters and threads on this forum that can give you more details on either.
09-13-2022, 06:40 PM | #3 |
Rep 4,480
I have a '21, the button to turn if off is gone so I used Bimmercode to disable it full time regardless of what mode I want to drive in.
BimmerGuyFL78594.00 |
09-13-2022, 07:55 PM | #4 |
Rep 1,022
I'll have to check Bimmercode but I have ASS disabled in 2 fields
Auto Start Function Auto Start Stop function memory Active Auto Start Stop function Not Active However, if I choose comfort, it will disable ASS. And since I have the Function Memory turned off, it will default back to ASS being turned on, the next time I get into the car if I -shut- the car off with Comfort Mode on last use. I don't think there is a coding that will auto turn it off each and every cold start ? |
09-14-2022, 06:24 AM | #8 | |
Rep 81
09-14-2022, 06:50 AM | #9 | |
13718
Rep 20,399
09-14-2022, 08:58 AM | #10 |
Rep 2,765
Drives: 2024 M4 Convertible
Kind of piggybacking on this a few questions
1) Does coding these options come anywhere close to messing with the warranty? I'm interested in some changes, but not if the dealer can find out. 2) I do actually like the stop/start function but sometimes want it off for a few days, is there a way to have it behave like the old method, where it remembers you've pressed it between shut-offs, I assume that's what the "memory" setting is? |
09-14-2022, 10:07 AM | #11 |
Rep 1,022
1) YYMV as sometimes things can blip . Dealer AFAIK won't see changes but if somehow something goes wrong during the code change.
Best suggestion I can say is just make sure you do it on a fully charged batter. Also OBD - via hardwire faster. Speed/faster = less time on battery drain. So do OBD-Wired (mobile device or iPad of your choosing) 2). Yes. On the 1st setting, it will save it's last state. So on next cold start, ASS will remain off if it was *off* from previous state |
09-14-2022, 10:19 AM | #12 |
Rep 1,218
My thoughts would be to leave it on, pretty well seemless restart with 48V battery.
2024 M60i Frozen pure grey/Black Merino
2023 M50i Tanzanite / Ivory/Night Blue Merino gone 2022 40i G05 Arctic grey/Ivory Merino gone |
X3_Alaska161.50 |
09-14-2022, 01:00 PM | #13 | |
Rep 4,480
09-14-2022, 01:05 PM | #14 |
105
Rep 319
09-14-2022, 01:15 PM | #15 | |
Rep 4,480
. Last edited by Marty in NY; 09-14-2022 at 01:22 PM.. |
09-14-2022, 01:34 PM | #16 |
Rep 744
I have the button and I leave it on, maybe I’m not in tune to the car but i can not remember a time that I thought, “hey the engine just turned off at this stop” or “wow, there was a lag between pushing the accelerator and the car jumping off the line.”
09-14-2022, 02:18 PM | #17 | |
13718
Rep 20,399
2. There is no way to make it remember the last state since the button is gone. When the button was first removed some folks coded theirs to remember and then set it to Sport to turn it off. It came back on with a restart. |
09-14-2022, 02:37 PM | #19 |
Rep 4,480
Depends on what you code. Let's take a very simple one for example. I coded mine to flash the turn signals 5 times instead of the default 3. So if I had my car at the dealers for service and they drove it and used the turn signals, they "might" catch the fact that its not at the OEM default and hence, must be coded. Then they "might" look for other coding examples.
09-14-2022, 02:37 PM | #20 |
13718
Rep 20,399
09-14-2022, 03:08 PM | #21 |
Rep 1,022
I see the POV on the remark: visual observation....if observed....vs. the computer diag. logs. I cannot see how that can trigger a red flag but I suppose under the right circumstances ..
09-14-2022, 07:49 PM | #22 |
Rep 1,110
I flashed mine off with Bimmercode. My understanding is that when a dealer installs a s/w update, it overwrites the Bimmercode changes, and they have to be re-flashed.
On my MB G550, I disconnected the charge current sensor on the main battery negative terminal. This makes the ASS system believe that the battery charge state won't support starting, so it suspends ASS. Don't know if this works for BMW, but if I get a s/w update that resets ASS, I'll try this before re-Bimmercoding it off again. |
