10-09-2022, 03:00 PM | #1 |
Rep 142
brake reset
Any help here? trying to reset maintenance lights. Pads are fine. Wear sensors have been disconnected for several years. fluid is fine.
10-10-2022, 07:21 AM | #3 |
Rep 142
I disconnected the wear sensors and have them zip tied to the chassis. I swap pads between summer pads that I track with and winter pads. cant really plug and unplug wear sensors every time I swap pads without breaking them and I dont need them since I check the pads a couple of times a year.
10-10-2022, 01:15 PM | #6 |
Rep 142
Yep. That’s what I did and that’s why i haven’t had a problem in the two years they’ve been disconnected. It looks like the car software is expecting pad and wear sensor replacement after a certain mileage or it thinks wear sensor is bad. Getting a scan Friday to see which it is.
10-10-2022, 06:57 PM | #7 |
Rep 2,208
Make sure your parking brake is off when you attempt the reset.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
10-15-2022, 07:57 AM | #9 |
Rep 142
Mystery solved. Even though wear sensor was plugged in but disconnected from pad and zip tied to chassis, somehow it all of sudden the wear sensor was sending a bad signal to computer. Replaced wear sensor with new one and all is good now. reset worked fine.
10-15-2022, 04:52 PM | #10 |
Rep 5,262
nice.. sometimes if the cable bends it will cut the wire inside and stop making contact
