10-23-2022, 12:23 AM | #1 |
Rep 15
2023 X5 45e camera image dim
Hi all, I picked up a 2023 45e just two weeks and am loving the car. However, one thing that I find quite annoying is that its backup camera's image is much dimmer than I'm used to (a '22 Accord Hybrid). The image brightness is fine during the day. However, at night, on streets that are not well lit, I have trouble seeing clearly what's behind the car beyond a few feet. At the exact street locations, the Accord's images are much brighter. The 45e's camera image settings don't help at all. I don't observe much difference even with the brightness cranked all the way up. I was wondering if other 45e owners have the same issue. Thanks!
10-23-2022, 06:29 AM | #2 |
Rep 443
Yeah, not a 45e specific issue but common across G05. I personally haven't noticed this - just backed down our driveway in the woods two nights ago - but I remember reading others sharing this same complaint. https://g05.bimmerpost.com/forums/sh....php?t=1824434
10-23-2022, 08:43 AM | #4 |
Rep 418
Is the issue the camera, or the reverse lights? The latter seem fairly worthless.
Mark
2022 X5 45e - Wife's daily driver
2023 GX460 - My daily driver 2017 JKU Sahara - Beach jeep 1988 4Runner on 40's - Off-road trailer queen 2001 PSD Excursion - The slave that drags the queen |
10-23-2022, 10:46 AM | #6 |
Rep 15
10-23-2022, 11:02 AM | #7 |
4992
Rep 11,891
Yep, the quality is very poor. I'm also referencing the surround cameras, which makes street parking at night difficult.
The E70 and F06 cameras were much better |
10-23-2022, 05:37 PM | #8 |
Rep 6,946
If you have the trailer hitch, there are a bunch of backup light assemblies that will clamp around it, but it has some implications about other automated systems that will think you have a trailer installed.
You can play with the brightness and contrast some in iDrive, and that will help at least a little. |
10-23-2022, 06:13 PM | #9 |
Rep 291
Yep.. I noticed the same thing on my 23... A little disappointed given my 5 year Q7 has better night time image quality. Daytime it's none issue.
But, the one feature on the Q7 where the camera image switch from rear to front when you shift to 'D' is the one I missed the most. I also don't like the automatic top down view on the front where it has gray out area, seems silly when pulling into a tight parking spot. Good thing BMW has such a good drivetrain and driving dynamics.. |
07-14-2023, 04:06 PM | #10 |
Rep 181
There was a bimmercode fix for poor instrument cluster lighting that may also address the night time backup image issue. Before doing the Bimmercode fix on my 2021 45e I had a booklight aimed at the sensor in the instrument cluster that vastly improved the night backup image. The instrument cluster lighting is much better after the fix but I haven't taken the car out at night since to test the backup lighting.
07-14-2023, 04:17 PM | #11 | |
Rep 213
How do you identify the location of the sensor in the instrument cluster?
X5 xDrive 45e 2023 / Mineral White / Tartufo / Anthracite-Brown Poplar
07-14-2023, 06:10 PM | #12 | |
13719
Rep 20,403
The sensor is on the left hand side of the IC.
RickObe93.00 |
07-14-2023, 10:16 PM | #13 |
Rep 181
The sensor is to the left (maybe an eight inch or so) of of the fuel gauge about at the 3/4 full mark. Try illuminating this area at night and you should notice a substantial difference in the quality of the back up image.
RickObe93.00 |
11-03-2023, 06:17 PM | #14 |
Rep 2
I just purchased a 2023 45e and can't believe how bad the cameras are at night. In my situation it's all cameras at night or when I pull in the garage at anytime. Some folks I've seen reference having the same problem with tinted windows stating that it's the sensor on the instrument cluster that causes the issue. I believe this is actually the culprit. It's the onscreen display that is too dim not the camera it-self. During daylight (not in garage) the display seems to be fine. I'm going to try the Bimmercode solution to see if it helps.
