      01-11-2023, 04:32 PM   #1
WellsX5
WellsX5's Avatar
Drives: 2022 X5 M-Sport
QuickJack 5000TL or 7000TL
Hello all, looks like Costco is having a sale on Quick Jacks and I've been wanting one for a while.
Does anyone know if the 5000TL will work or do I need to go to the 7000TL?
Thanks
2022 White X5 Xdrive40i M-Sport
      01-11-2023, 05:06 PM   #2
GerryC
GerryC's Avatar
4208
Drives: BMW Z4 M40i, BMW X5x40i
Since the published curb weight of your X40i is 4863 lb. and I don't know what may or may not be included - spare tire, full gas tank, other options - you're real close to the 5000 lb. rating of the 5000TL. And if you want to actually get in the car while it's lifted, you'll be over the rated capacity. For safety I'd opt for the 7000TL.
Double check, but I believe you'll also need the frame extensions as the lift points are closer to the 66" of the extensions. The basic lift can handle up to 60" between the lift points.
Gerry
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch
      01-11-2023, 05:13 PM   #3
weinerbarn
Unapologetic Tool Hoarder
weinerbarn's Avatar
1031
Drives: 2020 X5 M Competition
I was going to grab the 6000ELX. I'm waiting for them to go on sale again. The SEMA deal was actually cheaper than Black Friday and the gaf'd my emails and never responded when I tried to get in on the SEMA pricing.
      01-11-2023, 05:36 PM   #4
GerryC
GerryC's Avatar
4208
If it fits your cars, that's great. When it comes to something like Quick Jacks, it's about maximizing their utility.
The downside to the 6000ELX is that it just barely fits the X5 and it definitely wouldn't fit under my roadster. I could use the 7000TL on both vehicles with the extensions for the X5.
Gerry
      01-11-2023, 07:03 PM   #5
slicky
Drives: Cadilac CT4BW, X5 40i
Neither will not work well as they both have a 60" spread. You would need to buy an extension frame extending it to a 66" spread. Even then, you would have to set it up side to side instead of front to back and lift it to the side.
I wouldn't worry about the loading as there the safety factor on these things is x3 plus.
      01-11-2023, 08:44 PM   #6
eelnoraa
Drives: G05 X5
Can you explain this in a bit more detail?
2022 G05 B58/PHEV
+ a few very old BMWs
      01-11-2023, 09:46 PM   #7
WellsX5
WellsX5's Avatar
Gerry
Thanks Gerry,
Curb weight includes a full tank of gas from what I’ve researched so I should be good with the 5000tl weight , maybe go on a 1/4 tank gas to compensate for my weight..lol
So are the plastic rectangular pieces that protrude downward near the wheel wells the jack points? If so, it may be more than 66” center to each but I’ll have to check again. Extensions are $345 so I’ll be around $1700 if it works.
I’ll never own a heavier vehicle so all good there.
Other vehicle it’s mainly for is 21 Mach 1 , 3800lbs
      01-11-2023, 09:48 PM   #8
-DB-
28
Drives: X5MC GT500 Z06 Zl1
i have the 5000SLX and dont have an issue with either X5 and my last Trackhawk
while short to both lift points the front points and pinch weld with the rubbers work fine
I would not try side to side as that just looks like an issue waiting happen.
      01-11-2023, 09:48 PM   #9
WellsX5
WellsX5's Avatar
Why do you say side to side? Is front to back more than 66”?
What serviceability will I lose with side to side?
      01-11-2023, 09:50 PM   #10
WellsX5
WellsX5's Avatar
while short to both lift points the front points and pinchweld with the rubbers work fine
I don’t see any pinch welds, just lots of plastic on mine
      01-11-2023, 10:29 PM   #11
jad03060
Drives: X5 45e
Yes, the plastic cup thingies are the lift points for the vehicle. If it came with a jack, the end would fit in that cup. There are aftermarket pucks designed to fit in there so you don't damage the plastic by essentially transferring the load to the supported bottom of the cup.
      01-12-2023, 08:44 AM   #12
WellsX5
WellsX5's Avatar
Seems like the rubber pucks that come with the Quick jack should work fine.
      01-12-2023, 09:05 AM   #13
slicky
Yes the x5 lift points spread is longer than 66". 70" I want to say. Not sure on serviceability. It may be a bit awkward to move around underneath.
      01-12-2023, 09:25 AM   #14
WellsX5
WellsX5's Avatar
Main thing I would do is oil changes on the X5 so onto sure if it will effect the drain plug location
For tire rotation should be good
      01-12-2023, 04:21 PM   #15
eelnoraa
Drives: G05 X5
I think for oil change you definitely don’t need quick Jack, right? But I f course if you want it, sure get one. Even with a much lower car, I would be 1/2 way done by the time you setup the quick jack. And my guess is after the first oil change with this, you won’t bother at subsequent oil change.
Even add tire rotation, it still won’t make financial sense. At home you can only swap wheel, you cannot check balance. Personally I recommend going to a shop, have them check balance when wheels come off.
For this to make sense at home, bigger or more often job should be in plan.
      01-12-2023, 06:30 PM   #16
gfeiner97
Drives: X5 M60i
I came to the same conclusion when investigating quickjack for the G05 x5. I busted out my tape measure. The distance, front to back to center of each jack point is 71 inches on my '22 X5 40i. The sticker on the bottom of the B pillar says the my X5 40i is 6122 lbs. The only quick jack that can handle a 71 inch jack point spread is the 6000ELX but that model only has a 6000lb lift capacity. The FAQ in the manual says not to even slightly exceed the stated capacity:
Q: What if I want to raise a Vehicle that is slightly over the weight capacity of my QuickJack?
A: This is not an intended use of the product. We strongly recommend against trying to raise a Vehicle
that is heavier than the rated capacity of your QuickJack.
      01-12-2023, 07:39 PM   #17
eelnoraa
Drives: G05 X5
That number 6122 is gross weight, max total weight the car is designed for. It is curb weight + all payload ( people and cargo). Curb weight is the net weight of an empty car, which should be 4800ish for 40i
      01-12-2023, 08:01 PM   #18
WellsX5
WellsX5's Avatar
So for oil changes I’ll probably just use my rhino race ramps that won’t work on my 21 Mach 1 anymore. If it’s a huge pain to use the quick jack.
On the X5 this is mainly for tire rotation, and unless the car feels like it needs it I never get alignments when I rotate tires. When I modify my suspension, that’s a different story. Been all good for 28 years and many cars.
At the end of the day this is more for the Mustang and if it saves me a few hundred $ a year on tire rotations for the X5 or anything else that may occur then it pays for itself IMO.
gfeiner97149.50
      01-13-2023, 03:11 PM   #19
slicky
I agree Quick Jack is very time consuming to setup and is really for bigger projects that justify this time investment. I had big plans for it, but find that I hardly if ever use it.
eelnoraa3941.50
      01-13-2023, 03:56 PM   #20
eelnoraa
Drives: G05 X5
Agree. I wouldn't say pain to use. Just overkill for the purpose of oil change. For bigger job, it is probably the best jack average home owner can setup at home.
2022 G05 B58/PHEV
      01-16-2023, 07:58 AM   #21
WellsX5
WellsX5's Avatar
I figure if I do any work with a 1/4 tank of gas I will be couple hundred less than max weight.
I cannot stand taking my cars to dealerships, they are horrible and a huge waste of time.
weinerbarn1030.50
      01-17-2023, 03:26 PM   #22
TxT858
Drives: 2023 X5 45e
He means this...
gfeiner97149.50
