02-02-2023, 09:15 AM | #1 |
Rep 20
2023 X5 Spare Tire
Hi all,
I bought 2023 X5 M-Sport with staggered setup and it does come with a spare tire:
Note: this is my fist time owning a car with staggered setup and large wheels. With such large and wide tires, I was wondering if the spare tire is usable or safe. Has any one used the spare tire? Is there anything I need to be aware in using the spare tire other than obvious stuff (e.g., spare tire should be use in the emergency situation and not in extended duration)? Thank you! |
02-05-2023, 10:13 PM | #2 |
Rep 6,946
Read the user's manual? There's a speed limit and caution when using a space-saver tire. If you drive things like normal, you're at risk...keep the speed down and allow a little more room since the smaller contact patch will have less braking and cornering capability. It will work at either end of the vehicle.
