      04-26-2023, 12:31 AM   #1
adobeee
adobeee's Avatar
Drives: '23 X6 M50i
Question '23 X6 M50i exhaust valve timing
Hi all - I'm a newbie so wanted to ask if anyone knows the sensor timing of the valves to open/close on start up and while driving for a '23 X6 M50i?
On cold startup (comfort mode), I only feel hot air coming from the "inner" tailpipes on each side. Picture for reference:
After the engine is warmed up while parked, I rev to about 3-4k RPM and still only feel hot air coming out from the inner valves on each side (and not the exterior valve on each side).
Do I have a valve sensor timing issue here on startup and/or during revving while stationary? Or is this just the way the '23 M50i behaves? Is it any different while driving in sport mode?
FWIW I have a resonator delete and X-pipe welded at the spot. Picture for reference here:
Thanks in advance for your help!
